-   Engine/Power - EJ25T (STI and 2006+ WRX) (https://www.i-club.com/forums/engine-power-ej25t-sti-2006-wrx-90/)
-   -   My engine (https://www.i-club.com/forums/engine-power-ej25t-sti-2006-wrx-90/my-engine-260918/)
juan Aug 12, 2014 07:45 PM
My engine
So I got a rod nock on my engine for the second time, f warranty, I decided to either do it my self or have a subaru shop do it, not a dealer subaru. What's the best thing I should do guys? Me or a shop? And what's the best mods to do to get almost 450hp, and if you guys know a excellent shop?
de_engineered Aug 12, 2014 08:05 PM
[QUOTE=juan;3544185]And what's the best mods to do to get almost 450hp[/QUOTE]
[URL="http://forums.nasioc.com/forums/showthread.php?t=1393580"]Some reading material[/URL].
queeg9k Aug 31, 2014 04:11 PM
As de_engineered said, 450hp is A **** TON oh hp. Unless you have DEEP pockets I would not recommend shooting for that much. As for a shop that can take care of you check the vendor list here on i-club. I am sure if you talk to them about what you want from your car thy will be able to help you out.
northernsubie4 Apr 5, 2015 11:43 AM
I am running 512hp on my rotated setup. To make 450 you will need to upgrade all your fuelling, ie injectors,fuel pump , fuel rails. Then you need to build your motor with forged internals which are not cheap. I suggest getting a shop to do the motor unless your a pro. There's a lot of machine work that needs to be done so having a shop do it they can just send all the machine work out. I just did my own motor and I had a hell of a time because of special tools and other random stuff. I got it done but took me a bit. If your not in a rush do it yourself but if you R take it to shop. They should warranty your new motor too if you get a shop to do it. I suggest staying at stock power. You will lose reliability once you do what I did lol. I am broke
rahulkentonn May 5, 2016 08:05 AM
I had a similar problem last year so I ended up buying a JDM engine.
