K&N typhoon is it crap?
yo yo, whats up with this mod. Do you think this will really give a 12 whp. Or do you think it'll trip the maf, and in turn retard the engine. Cause I here that all of the intakes throw the **** outta wack.http://www.knfilterchargers.com/sear...rod=69-8001TWR
Save your money. Intakes including the K&N generally don't add any power on factory turbo cars because the factory airbox is not a restriction at near stock power levels.
In my WRX, I don't even use the K&N replacement filter in the stock airbox because it is more restrictive than the factory disposable paper element. The reason for this is because the factory element has many more folded pleats for much greater effective surface area. The way the K&N is constructed is very high quality but in a Subaru replacement panel filter it just can't fit enough pleats in such a small area.
I've used K&N filters in the past and while they work great on carbureted vehicles, I don't like the hassle of cleaning and re-oiling the element because it's easy to over-oil and foul up the MAF sensor if you're not experienced with these filters.
Origami posted by dsmperformance
http://www.imprezawrxsti.com/postnuk...wtopic&t=16342
In my WRX, I don't even use the K&N replacement filter in the stock airbox because it is more restrictive than the factory disposable paper element.--
I would love to see some flow bench numbers. I find that hard to believe. It would be a great shoot out to take a Typhoon, stock box, stock w/ k&n and another brand CIA and put them all on a flow bench and see the true CFM gains. Although CFM and actual power gain are two different things.
I dont know.... just a thought.
-Mike
Car Info: Sold my 05 Evo...Carless for a while...then 05' WRB STi whenever lol :(
Originally Posted by AndyH
Dyno-proven HP gains, but at the expense of not filtering the incoming air as well as a paper filter. You decide if the trade-off is worth it for you.
K&N filters are some of the best filters out there?
Dahveed aka Robin Hood
oiled filters such as K&N shouldn't be used with modern hot-film MAF sensors that are in our cars.
I had this problem on my old '02 wrx, the oil was making my MAF go nuts.
What filters are NOT paper?
also per instructions from K&N the filter is NOT oiled.
Donttryme
Donttryme
Donttryme
the JDM STi filter I use is cotton, not paper.
K&N's are cotton or some other fiber cloth, and YES, they are oiled, I've been around them long enough.
Car Info: 2005 Metallic Gray STI
I read about this too in Import Tuner Magazine that the "new" K & N typoon adds up HP to WRX STI.
My question is that.... does this filter works the same with the regular WRX ( non-STI)?
I know K & N filters are good but it this really true for WRXs?
Ric-STi-R
Aug 7, 2008 07:38 PM
AdamBOMB_STi
May 10, 2006 03:22 PM
