high flow fuel pump and injectors
Car Info: 2008 subaru impreza wrx sti
I have a 2008 sti and Im tring to figure out the best fuel pump and injector set for it anyone who has a good setup that could help me out would be appreciated
Posted from I-club.com App for Android
What kind of power numbers are you trying to hit? This will determine the size of both the fuel pump and injectors. Also, what fuel do you want to use?
If keeping things more mild than wild, DW65c should cover all your needs.
If using E85 with a giant turbo... well, there's nothing good off the shelf and you have to either hack up the guts of your hangar or go with a surge tank + external pump setup in addition to an in-tank DW65c.
Car Info: LUMPY CGM 05 WRX
As stated already What are your power goals.
Base your fuel needs off from this. Your tuner can tell you what size injectors you need, and what fuerl pump to go with.
My setup and im making damn near 400hp on a low reading dyno is
ID 1000cc's and a walboro 255. I am on e85 and a hybrid motor with cams running a dom 3 xtr. The 255 will handle around 400 and a little plus.
cuscogdb
May 11, 2010 03:54 PM
dan2304k
Wanted
May 25, 2006 04:28 PM
ImprezaRSX
Feb 3, 2004 02:09 PM
Rallysportz
Aug 29, 2003 08:13 AM
JohnB
Jun 30, 2003 12:14 PM
