Cruise control Shuts Off?
Old Apr 21, 2009 | 09:38 PM
C89ZX7R's Avatar
banned
Car Info: 2004 STi
2004 STi
Went for a drive and set the cruise control at 70mph. Twenty minutes into the drive the cruise control shuts off. The set light disappears but the cruise stays on. No it wasn't a check engine light or a misfire. Reset the cruise back to 70mph and it did it again ten miles later. Took the exit ramp and got back on going back the way I was coming from. Set the cruise back on and it didn't do it. Any suggestions?
Old Apr 21, 2009 | 11:13 PM
latebrake's Avatar
Car Info: 08 STI
thats a little wierd... mine doesnt set at above 79
Old Apr 21, 2009 | 11:49 PM
C89ZX7R's Avatar
banned
Car Info: 2004 STi
its kinda freaky when it does it since your not expecting it.
Old Apr 28, 2009 | 10:05 AM
code3suby's Avatar
Car Info: 97' Dodge Cummins and an RSTI thingie
Might check it with a code reader? I was doing this for a while, and the CEL didn't come on, but I checked and there was a pending o2 sensor code. I think it was just on the borderline to not throw a CEL.
Old May 24, 2009 | 04:07 AM
monsterboy's Avatar
Car Info: 04 STI
how high or low were you're rpms when it shut off? If you are going up a steep hill with low rpms (especially with bad gas) then it will shut off if there is the remotest possibility of stalling and/or lugging the motor
Old May 24, 2009 | 01:51 PM
tony1w's Avatar
Car Info: 03 Bugeye, D675, Lightning
look under the dash. Locate the clutch petal. On the petal there is a plastic tab that pushes on a "push-in" type switch. Make sure the plastic tab on the clutch petal arm is in good shape and it is all adjusted properly. It could be worn down.
ej20_wagn
17
Sep 20, 2011 10:29 AM
Lowend
Aug 17, 2011 11:38 AM
Irrational X
Jan 20, 2009 05:13 PM
Salty
Aug 9, 2004 01:23 PM
