Added el header and 73mm intake lost power
Old May 10, 2014 | 08:07 PM
calitmax's Avatar
Car Info: Flared 2007 STI, EQ built and tuned
2007 sti
engine mods-
gtx3071r
process west tmic
dynamics 1000cc injectors
3in turbo inlet hose
255 walbro fuel pump
invidia bellmouth catless dp
BEFORE-------------------AFTER-
38mm ewg---------------44mm ewg
eq uppipe ----------------tomei uppipe
AEM cai-------------------tomei el header
----------------------------kstech 73mm big MAF
330whp 320whp
compression leak down test was good.
tuned by EQ. Ed said when he turned up the boost it would knock. Up the timing it would knock. knock sensor might be bad.
Does anyone have any ideas of whats going on with my car.
Old May 10, 2014 | 08:28 PM
SkizzDawg's Avatar
Car Info: 2006 STI
What about going back to the 38mm wastegate?
Old May 11, 2014 | 05:24 PM
calitmax's Avatar
I don't think that would effect peak power. On that note my old ewg was on the uppipe and now its on the turbo. But I still don't think that would change anything
Old May 11, 2014 | 06:25 PM
awdorgtfo's Avatar
Car Info: 07 UGM WRX Wagon
Find a new tuner
How could you ask us what your problem is if we don't know any history on your car. Your tuner didn't seem to even be any help.
Old May 12, 2014 | 07:02 PM
calitmax's Avatar
Originally Posted by awdorgtfo
Find a new tuner
I thought I gave enough of the history above. What else is power related?
The car was running top notch before the installation. The only things that have changed are the parts listed above. The motor was built a year and a half ago. The motor is good. Most sensors have not been changed.
The car still runs good just less hp.
I was hoping someone else has had the same problem and had it fixed.
Old May 13, 2014 | 10:41 AM
Heedz's Avatar
Nobody likes the tuna here
Did you retune?
Old May 13, 2014 | 11:24 AM
flat489's Avatar
Car Info: '11 STI
Originally Posted by Heedz
Did you retune?
and were both tunes by Ed? if you are comparing 2 numbers on different dynos this thread is useless
Old May 13, 2014 | 11:34 AM
bmxhotsauce's Avatar
Car Info: subaru
did you retune????? im sure ed would have help you figure it out if you would have asked him
Old May 15, 2014 | 08:05 PM
calitmax's Avatar
ya it was retuned. He had to detune it cuz it was knocking. In the last few days ive noticed it hesitating from time to time. So im thinking its the knock sensor, I hope. Has anyone here ever had their knock sensor go out on them?
Thank you for your input
Old May 15, 2014 | 08:15 PM
calitmax's Avatar
I talked to him. He said he wasn't 100% sure on what the problem is. He said it could be the sensor (not his exact words). I figured someone out there has had this problem and would know what to do. To save me time and money.
Old May 15, 2014 | 09:07 PM
subi4justin's Avatar
Car Info: 2015 SWP WRX
Go to a different tuner? Never a good thing when your tuner has no idea why your making less power or why it's not running correct.
Old May 16, 2014 | 12:20 AM
Heedz's Avatar
Lol cause it was knocking LOLs
Old May 16, 2014 | 07:45 AM
CBSubie's Avatar
Car Info: 2005 STi
Smh...
Old May 20, 2014 | 08:18 AM
ddavis's Avatar
Car Info: 04 wagon
I would check out the knock sensor & make sure you have good gas in the car. Is that on 91oct?
Old May 23, 2014 | 11:21 AM
WRXncrew's Avatar
Car Info: http://goo.gl/XpkO0b & '99 SF 'S'
Ask Mike @ GST Motorsports and he's having a tuning special for Memorial Day! Yay!
