420hp???
Old Dec 7, 2003 | 06:28 AM
JonniesBR's Avatar
Question 420hp???
Hello everybody, i´m new to this so please pacience (and i´m also brazilian, sorry for the english). I have an sti, but it´s the european model... and i want to go past 400 hp, something close to 420hp...i´m thinkig in installing: aps intake, fmic aps dr 650, a pe1820 turbo, cusco header, perrin catless uppipe and downpipe, JIC cat back full titanium, turboxs utec. Do you guys think that´s enough to put my baby running 420 hp???? Wich bov should i go fo???Do i need to change my fuel managment like getting perin fuel rail and some 650cc injectors and a walbro 255??? Any suggestion??? Would it be too lagy??? do i really need the fmic or sti tmic can handled it??
thanks for the help guys!!!
Old Dec 8, 2003 | 12:52 AM
international B's Avatar
Chewwwwy
i wouldnt reccomend the utec. if its the same 2.0 engine as the jdm model then i dont think 420 hp is out of the question.
Old Dec 8, 2003 | 07:16 AM
JonniesBR's Avatar
so what you guys recomend for ecu
Old Dec 8, 2003 | 07:26 AM
JonniesBR's Avatar
wwhat about the aps engine management
Old Dec 8, 2003 | 01:36 PM
Chewwwwy
i would reccomend a xede.
Old Dec 9, 2003 | 07:07 AM
JonniesBR's Avatar
i was doing some research then a i found the aps 3.5 exhaust (together with their 3.5 inch downpipe) would it be better than the JIC full ti, has anyone installed that
Old Dec 10, 2003 | 07:44 PM
god's Avatar
god
My stage 2 package is over 400 HP at the crank. If you are looking at 400 whp that is much more difficult as you'll need a bigger turbo, 850cc injectors, fuel pump and larger MAF housing pipe which has to be custom made. I am using Greddy E-Manage for fuel management and it works perfectly. I do not recommend changing cat back exhaust unless you fully hand port the turbo. It wil boost creep otherwise.
Old Dec 11, 2003 | 07:23 AM
JonniesBR's Avatar
no, i really ment 420hp not whp, i think 420 hp i a little bit over 300whp, isn´t right...
why don´t you recommend cat back, even if using a pe 1820
could you tell me what are your mods, and if it´s more lagy than the stock
thanks
Old Dec 20, 2003 | 07:42 AM
JonniesBR's Avatar
and do you guys know if the aps tmic can handle the pe1820 turbo or do i need to go with the dr650 fmic????\\\\\\because with the ymic it would be a lot less lag, isn´t it???
Old Dec 26, 2003 | 03:19 AM
dr3d1zzl3's Avatar
Car Info: 08 sti
On a 2.0 (you said euro version) im sure you would be at about 300+ whp with that setup. What year motor and sti do you have?
(im brasilian as well, well half of me is)
Old Dec 29, 2003 | 10:22 AM
JonniesBR's Avatar
it´s a 2004 sti, what do you think
which ic should i go with tmic or fmic
thx
ps hehehe i´m half brazilian too, my familiy is portuguese...
Old Jan 2, 2004 | 03:35 PM
dr3d1zzl3's Avatar
Car Info: 08 sti
on a 2.5 that should be a nice setup. Thinking of doing a 04 stii as well but the new legacy is gonna be hard to pass on.
Old Jan 15, 2004 | 12:31 AM
ChristianR's Avatar
From: 460bhp+ 420torque+ 2.5litre TypeR- Jersey,CI,UK
Car Info: 460bhp+ 420torque+ 2.5litre TypeR- Jersey,CI,UK
I would go ask the same question on bbs.22b.com
