300whp safely???
Old Jan 25, 2012 | 09:59 PM
paullawalla's Avatar
Car Info: Subaru Wrx TR 2007
300whp safely???
i was just looking for ideas to reach 300whp safely on my 07 wrx TR. any suggestions or ideas?
Old Jan 25, 2012 | 10:01 PM
silverbullet415's Avatar
turbo back, fuel pump might get u around 270ish
Old Jan 25, 2012 | 10:06 PM
i was thinking about getting a catless dp and getting tuned right now im all stock just an invidia N1 catback exhaust
Old Jan 25, 2012 | 10:14 PM
04caliwrx's Avatar
Its a Subaru engine so nothing is safe, with 300whp a list of problem can come up. Tray is one big one that is not cheap. If you have 300whp have some money set aside for when things go wrong. Happy building
Old Jan 25, 2012 | 10:18 PM
subi4justin's Avatar
Car Info: 2015 SWP WRX
Safely, you'll def need a full turbo back exhaust, intake, header, fuel pump, injectors and a slightly larger turbo depending on if your staying 91 octane. If you went e85 then you can skip the larger turbo and just do the full bolt ons. Just be careful pushing that much power with that fragile 5-speed. Hope that helps
Old Jan 25, 2012 | 10:23 PM
debbid's Avatar
Does a fuel pump really make that much of a difference? My 07 (non-TR) has a catless DP, catback, and a road tune from EQ and it's making about 220 hp and 270 ft/lbs. Although, I don't actually know what's different on the TR and the normal WRX. So, I could be totally wrong.
Old Jan 25, 2012 | 10:24 PM
yea thanks i was thinking a 20g turbo but what size injectors and fuel pump ? and i dont launch my car and i know i would need to roll before i hit the throttle so trany wont take to much of a beating haha
Old Jan 25, 2012 | 10:26 PM
xhengmanx's Avatar
Im on 1000cc, walbro fuel pump, fp18g td05, with fmic and intake along with a full catless tbe, headers and ewg setup tuned on e95 and im pushing at 335wtq and 348 whp. You can probably get 300+ with the same setup but with a tmic.
Old Jan 25, 2012 | 10:30 PM
yea that sounds good but i think i would need the 20g cuz i wanna stay on 91 octane pump gas as it is my daily driver i like the fmic too
Old Jan 25, 2012 | 10:44 PM
KrAzYkld's Avatar
Car Info: 1998 M3, 2016 WRX
My friend was able to crack 300WHP with a VF48 in his 2003 WRX. He had EL headers, EWG, TMIC, CAI, injectors, fuel pump, turbo inlet, full exhaust, and protune.
Old Jan 25, 2012 | 10:58 PM
achavez's Avatar
Car Info: sold: 06 wrx
<----- 20g 91 oct EQ tuned. with a conservative tune on a 20g you should be at or slightly above 300whp. i think as long as you dont drive your car like a jackass you should be fine motor and tranny wise
Old Jan 26, 2012 | 12:57 AM
Heedz's Avatar
Nobody likes the tuna here
I see that you live in Pollack Pines, yes I would stay with 91 since you're in such a rural area. Also, it may be wise and get a road tune up there if you are altitude changing a lot aka going up tahoe because the elevation is definitely something that could make or break your car in power wise IMHO, you don't have the weak tranny like the bugeyes did but definitely 300 is the mark where you do uh oh I have to drive careful. Try a tune maybe grab an AP with a downpipe and see how you like that power, maybe headers along with it and an STi intercooler, if not swap a vf39/43/48 youre keeping stock specs at that point might be safer, since its more of an OEM swap. you could probably hit 280 around there with a stock turbo thats not a TD04. But switching aftermarket does give you less taper towards top end if that is what you want. Determine your set up via where you want your powerband to be.
Old Jan 26, 2012 | 08:35 AM
I'm all over the place from tahoe to Folsom tahoe for snowboarding and Folsom for school so I'm not really looking for a road tune. Thanks for all the helpful advise guys
Old Jan 26, 2012 | 08:54 AM
DerekB707's Avatar
Car Info: 07 rs STi swapped Rotated BW S200SX-56
You will need all the basic supporting mod and something a little better than a vf-39. I have seen one actually hit 300whp, but I don't think it was very common. My 06 TR with a vf, STi tmic, EL header, MBC, Full 3" TBE, UP, K&N typhoon made 291/322 tuned by EQ. If you really want 300, I would suggest an 18G or larger with our crappy 91 oct.
I wouldn't push those 07 pistons you have too hard, they are prone to broken ringlands.
Old Jan 30, 2012 | 10:16 PM
Cool thanks for the input guys also any recommendations for any brand fmic and what dimensions fit the best??
