2015 subaru wrx blow off valve
Old Oct 30, 2014 | 08:56 PM
alex2001's Avatar
Car Info: 2012 subaru wrx
hello subie friends,
i was a question has anyone out there install a GFB blow off valve on their 2015 wrx and know the proper adjustment my car stall when i rev the car it goes under 1000rmph and it does not idle normally
Old Oct 31, 2014 | 07:55 PM
subysteez's Avatar
If it's not a reciculating bov, do your motor a favor and reinstall the stock bpv. Its most likely idling like crap because your AFR is out of whack. atmosphereic (ones that don't recicrculate) BOV's should only be installed on cars running high boost.
If yours is reciculating.. I don't know why your idle is off. Most come preset to prevent such issues.
Old Oct 31, 2014 | 08:07 PM
silverbullet415's Avatar
Put the stock one back
Old Oct 31, 2014 | 08:33 PM
awdorgtfo's Avatar
Car Info: 07 UGM WRX Wagon
There shouldn't be any problems like this. It just needs to be adjusted properly.
Old Nov 1, 2014 | 07:52 AM
norcalbro's Avatar
Car Info: 2010 swp WRX hatch
Yeah. Our cars require a bpv (full recirculating) or they run like crap.
The air comes in through the intake filter, passes the MAF sensor that measures how much air there is. When the bpv releases, the car is already counting on that air being recirculated back into the intake and adds the appropriate amount of fuel. If you have a bov (vent even partially to atmosphere) then you are releasing the air that your car is eexpecting to be using. Now its adding fuel but not getting enough air, making you run super rich...
The only way to properly run a bov is to get tuned for it. Your tuner can adjust afrs to compensate for the lost air.
RallySportDirect
Engine and Drivetrain
Nov 24, 2009 12:54 PM
06d
Oct 7, 2007 01:08 AM
Black797
Aug 17, 2007 09:15 PM
Miwxq
Jun 22, 2006 02:39 AM
dgflwrx
May 12, 2003 02:21 PM
