06 WRX negative fuel trims @ low load & rpm
Old 07-26-2018, 10:05 AM
Bill Peralta's Avatar
Car Info: USDM 2006 WRX Wagon
Hi all,
I have a 2006 WRX wagon with 160k miles, currently on Cobb Stage 1+EBCS ACN91oct. Having some slightly concerning readings for AF Learning.
At idle, my AF Learning 1 has dropped down as low as -8.25%, which is further than the +/- 5-8% that Cobb deems is healthy. I don't believe it's a tuning related issue since I've been on the Stage 1 tune for about 2,000 miles now without issue.
While cruising around 2500 RPM, AF Learning 1 is around -5%. When I give more than 30% throttle, AF Learning 1 is between -2.74% and 0%.
The only positive fuel trim I've seen was +0.78% on rare occasions when letting off the throttle.
AF Learning A = -8%
AF Learning B = -5.5%
AF Learning C = -4%
AF Learning D = 0 (I believe Cobb did this intentionally, as the car would be in open loop at this point)
Used seafoam through BPV vacuum line, and cleaned the MAF about 1,000 miles ago. I'm reaching target boost (~14psi) just fine.
I've emailed Cobb as well. Anyone have advice on this?
Bill Peralta is offline
Mean Gene
01-05-2018 05:46 PM
srbaugust
15
06-02-2013 02:02 AM
quiksilver
09-14-2006 11:15 AM
sinatra
03-23-2005 04:06 PM
mhorowitz8
10-25-2004 08:40 PM
Quick Reply: 06 WRX negative fuel trims @ low load & rpm
