06 WRX negative fuel trims @ low load & rpm
Old Jul 26, 2018 | 10:05 AM
Bill Peralta's Avatar
Car Info: USDM 2006 WRX Wagon
Hi all,
I have a 2006 WRX wagon with 160k miles, currently on Cobb Stage 1+EBCS ACN91oct. Having some slightly concerning readings for AF Learning.
At idle, my AF Learning 1 has dropped down as low as -8.25%, which is further than the +/- 5-8% that Cobb deems is healthy. I don't believe it's a tuning related issue since I've been on the Stage 1 tune for about 2,000 miles now without issue.
While cruising around 2500 RPM, AF Learning 1 is around -5%. When I give more than 30% throttle, AF Learning 1 is between -2.74% and 0%.
The only positive fuel trim I've seen was +0.78% on rare occasions when letting off the throttle.
AF Learning A = -8%
AF Learning B = -5.5%
AF Learning C = -4%
AF Learning D = 0 (I believe Cobb did this intentionally, as the car would be in open loop at this point)
Used seafoam through BPV vacuum line, and cleaned the MAF about 1,000 miles ago. I'm reaching target boost (~14psi) just fine.
I've emailed Cobb as well. Anyone have advice on this?
Mean Gene
Jan 5, 2018 05:46 PM
srbaugust
15
Jun 2, 2013 02:02 AM
quiksilver
Sep 14, 2006 11:15 AM
sinatra
Mar 23, 2005 04:06 PM
mhorowitz8
Oct 25, 2004 08:40 PM
