weird noise
Old Feb 5, 2003 | 04:49 PM
BlueGargantua's Avatar
winding??? at what speed? I know that some guys hear a shrieik or "whine" from the wind at or around 120 cause of the wind on the mirrors. I dunno
Old Feb 6, 2003 | 11:06 AM
mmboost's Avatar
Is it as you go faster or when sustain high accelleration? I know dumb assumption, but maybe you're just hearing the turbo spool up That's the first thing I thought when I read you post.
jason
Old Feb 6, 2003 | 12:29 PM
bamfwrx's Avatar
Car Info: 02 WRX
try changing your rear tire pressure
say 3-5 psi higher than front
I know it sounds odd but it solved the noise I had
Old Feb 6, 2003 | 10:58 PM
mmboost's Avatar
The brake sensor has always sounded to me more like a scraping, if that helps.
FWIW - I had some cheapy pads put on another car of mine a while back and both sets had sensors which BROKE OFF PREMATURELY and basically got stuck in the break mechanism. Thank God they didn't hamper the caliper performance, but they did exactly what you are saying, scraping all the time. Once in a while it would suddenly stop, but only to come back in full force no matter what I was doing.
I had confirmed this by simply taking off the wheel, pulling up the caliper and watching the broken sensor fall out and clink on the ground.
jason
JoKeR 13
Oct 7, 2003 08:57 PM
WyldKardzWRX
Jul 23, 2003 10:31 AM
WrxKiDD
Jun 11, 2003 11:27 PM
Aussie Rex
May 12, 2003 10:47 AM
ges311
Apr 3, 2003 07:00 PM
