Is there a specific thread on Cobb Stage 2 vs. Prodrive Stage 3?
Old May 2, 2004 | 01:47 AM
psychobooe's Avatar
One thing to keep in mind, the Cobb Stage 2 does not include an uppipe either. The addition of the uppipe and the intercooler hose gives probably about 5 or more wheel hp. Plus, Cobb is very respected in the Subaru tuning community. Obviously Prodrive is also, but how many people are running the Prodrive power packs versus the Cobb AccessPORT? Go with Cobb and you'll never look back.
psycho
Old May 2, 2004 | 10:18 AM
MO REX's Avatar
Car Info: 02 PSM WRX
Cobb's 0-60 and 1/4 times are based on the average times of their costomers. Cobb's stage 1 is close to the results of the prodrive and it is just the $600 Accessport on a stock WRX. Like psychobooe said I would go with Cobb's stage 2 since IMO it is better and with the extra $800 you could buy an upipe and do some suspension work which will make your WRX handel a lot better. My Accessport is on order and I cant wait. Also dont forget Cobb will be comeing out with the street tuner which will allow you to custom tune your car. If you want to do this in the future all you have to do is send them your accessport and they will send you the street tuner and only charge you the difference of the 2.
Cobb stage 1
0-60=4.9
1/4 mile=13.9 @96
Old May 2, 2004 | 11:12 AM
RussB's Avatar
Car Info: $200,000 sports car
the prodrive dyno chart shows HP and boost (kpa) not torque. the cobb dyno chart shows HP and torque. The cobb chart is from a mustang dyno, which are notorious for reading lower than any other dyno's. with the cobb setup you are paying for tuning done in american driving conditions using american gas. with the prodrive setup, you are paying for the name.
Old May 3, 2004 | 12:20 PM
awns729's Avatar
Car Info: want a WRX
casualsurfer, you seem to know more than a lot of the people here. i cant think of you as a newb good info!
i'd go with cobb also
Old May 3, 2004 | 12:37 PM
esracer's Avatar
Car Info: 2002 Honda S2000
I would go with cobb also, with the accessport you'll never have to buy a reflash again. You just add your parts and download the corresponding map. I think that's a very good option.
Old May 3, 2004 | 01:56 PM
esracer's Avatar
Originally posted by casualsurfer
Question: what's the difference between Cobb's ECU and Cobb's AccessPort handheld device? Should I get both?
Cobb ECU: You have to take your ECU out of the car and send it in to get reflashed.
Accessport: Handheld device that stores maps so that lets you switch the maps while your ECU is still in your car without sending your ECU in. You do this by connecting the accessport to the OBDII connector to set your maps.
Another thing that's good about Accessport:
You can only flash your ECU a certain amount of times before you wear out the memory. With Accessport you only flash your ECU once, and just load up the maps whenever you want, no worries.
Old May 3, 2004 | 03:24 PM
GottaREX's Avatar
Car Info: 02 WRX
Between Prodrive and Cobb Tuning, there's not a whole lot difference between them. Now compare the prices though . The cost alone should definitely help you decide. I have a reflashed ECU from Cobb Tuning, their reasonable prices and great customer service makes it all worth it. Still patiently awaiting for my Accessport. :banana:
srbaugust
15
Jun 2, 2013 02:02 AM
GT35 STI
Sep 5, 2008 11:27 AM
Irrational X
Jul 13, 2008 09:04 AM
Impretzle
Aug 31, 2005 05:30 PM
Impretzle
Mar 11, 2005 04:07 PM
