Smoking from tail pipe. help needed!
Old Nov 5, 2015 | 08:56 AM
Xlagman92's Avatar
Car Info: 2002 subaru wrx
so the other day i noticed smoke coming from my tail pipe, cant tell if its blue or white. i thought it was a headgasket, till i did compression test and leak down. leak down was at 15% and compression was 145 straight across. no bubbles in radiator or coolant resevoir, and no milky oil dipstick. so i pulled my down pipe and saw a puddle of what seems to be coolant or oil, cant tell since its all black. i did pull the intercooler and saw no oil inside as well. is it possible the turbo is leaking only on the exhaust side? ill post a pic to be more clear. any help?
my guess is turbo seal starting to go?
car still holds boost fine and i see no loss in power. ill try and post a video of car smoking as well
vf39, sti pinks, sti tmic, 3 port gm bcs, xpt tune
Old Nov 10, 2015 | 05:17 PM
xthach_93's Avatar
Car Info: 2003 WRX Sedan
I'm actually on the same boat. White smokes blowing out but no visible signs of leak/power lost/head gasket/oil/etc. (Smell like..... Smells like an exhaust)
Only note is that my heater core is plugged/bypassed (By Previous owner) because I have no heat with the heater on (Car is not overheating) - Just did the timing service so everything was flushed/burped. (Thermostat is not stuck opened either)
My possible conclusion was that it was just condensation (It's getting colder) or a very minimal leak somewhere not seen. But I ain't no mechanic so don't take my word for it.
If anyone else has some input on this, I'd like to know as I'm intrigued to learn more.
Old Nov 16, 2015 | 07:52 AM
waffrx's Avatar
Condensation, use ur finger n touch ur tail pipe n see if water is common out
Old Nov 19, 2015 | 12:09 PM
Xlagman92's Avatar
it was my turbo. swapped it out and no more smoke. my turbo seal was def on its way out
Old Nov 19, 2015 | 12:10 PM
Xlagman92's Avatar
i also did the block tester to check for headgasket leaks, and it passed. liquid stayed blue with no hint of yellow.
Old Jan 1, 2016 | 10:35 PM
xthach_93's Avatar
thank you for the info, definitely gonna swap out my turbo out soon after i do a compression/leak down test.
t-wrexxx
Aug 30, 2004 06:05 PM
bao ling
Sep 8, 2003 02:32 PM
aloose
Jun 8, 2003 04:30 PM
EtchyLives
May 17, 2003 11:21 PM
ted1186
May 3, 2003 09:57 AM
