-   Engine/Power - EJ20T (pre-2006 WRX and JDM) (https://www.i-club.com/forums/engine-power-ej20t-pre-2006-wrx-jdm-60/)
-   -   radiator question (https://www.i-club.com/forums/engine-power-ej20t-pre-2006-wrx-jdm-60/radiator-question-202781/)
hypnotics06 Apr 21, 2009 08:22 AM
radiator question
I'm putting an aluminum radiator in my 04 WRX wagon this afternoon. Is there any specific coolant that needs to go in like a more high performance coolant? Or can the regular conventional coolant go in? just want to make sure i'm putting the right stuff in.
silvergga Apr 27, 2009 06:16 PM
Use the OEM Subaru coolant and mix it with distilled water.
sigma pi Apr 27, 2009 07:33 PM
OK you can use regular prestone
you can use the OE subaru stuff thats old its green too
subaru now has a long life coolant its blue
it can all be mixed together
but when you mis only use distilled water or else tap water eats at the metal
MattK1 Apr 30, 2009 06:44 PM
I spoke to a tech at Royal Purple when I installed my aluminum radiator. He said if you want to use rap water you can, just let the water sit out over night. He says that the minerals that can harm your rad will disipate. I just went to the store and bought a gal of distilled for $1. I also used regular green Peak 100% coolant(not pre-mixed).
sigma pi May 1, 2009 08:57 AM
disipate where?
i would think the water would evaporate leaving the minerals behind
but what do i know i was a literature major
venom225 May 3, 2009 10:30 AM
^^^was thinking same thing.....
