overboosting! ah help
ok i have a blitz dual turbo timer/ boost gauge. i used the peak hold display and i set it at .95 hkpa (13.8 psi) for the warning. every time i hit it i get above that, and my peak hold display says 1.07 hkpa!!!! WTF is there something wrong with my car or i just really hope that the turbo timer/boost gauge is really really unaccurate.
Car Info: 2003 PSM STi
yea, a turbo timer is NOT the same thing as a boost controller.
-Ted
edit: 1.07 kpa is about the normal stock boost level for a WRX
edit again: I am not 100% sure, but I believe, that the boost display you are looking at is just for reference, so you can refer back to it later, to see what your maximum boost level was for the duration of your drive. This information is good for tuning the car, but doesnt actually regulate the boost pressure....you need a boost controller for that.
-Ted
i didnt say i was using a boost controller, simply my turbo timer is just a boost gauge with other functions, it has peak hold display which shows highest boost achieved, and it has a warning function that beeps wen u set the warning boost, im not that stupid i know its not a boost controller
Originally Posted by vteckiller1005
its pretty close i have the blitz turbo timer and an autometer boost gauge and I think its about 1.00hkpa = 15 psi
1 bar=14.50377 psi. If you dont beleive me check it out here http://www.joshmadison.com/software/convert/dl.asp.
I'm no guru or anything but from what I have read 13.5 psi is the stock setting for a WRX and 14.5 for a STI. Cobb stage 1 has a boost target of 14.7 +/- .5 psi depending on vehicle and conditions. You are running close to what I am at stage 2 so I would hope your gauge is off if I were you.
Originally Posted by de pilipino guy
so what would 1.20 or 1.32 hkpa be in psi..sorry stupid question.
1.20 hkpa=17.4psi
1.32 hkpa=19.14psi
If 1 hkpa= 14.5 psi then all you need to do is multiply hkpa by 14.5 (psi) so 1.20X14.5=17.4. If your in the car and dont have a calculator near by just remember 1 hkpa=14.5 and for every .1 hkpa over or under 1 you add or subtract 1.45 psi.
107kPa = 15.5 PSI Stock is around 14.0 PSI, depending on what you read. Overboosting by 1.5PSI is no laughing matter.
Where is your Blitz boost line hooked up? At the BOV? At the ECU's source (just infront of the intake manifold)? What mods do you have? What where do you live (country, state) ?
Also, note that aftermarket gauges (even spiffy digital Blitz ones) are not reading what the ECU is, and what the ECU reads its what's important. I know this for a fact, as my Blitz Spec-R boost controller which also has the meter/peak/hold capability was ALWAYS 0.5 to 1.0 PSI off from my UTEC... and the UTEC reads the ECU's sensors. FWIW, readings seem at least a little more accurate when done from the intake manifold.
jason
jason
