i need help!!!
Old Sep 10, 2003 | 04:04 PM
Mulder's Avatar
Car Info: 02 WRX WRB
Do you have a boost gauge? If not better get one ASAP as that is the only way to safely adjust an aftermarket boost controller. You can't just crank it up "a few turns" and take off. Chances are you are overboosting and the jerking is the ECU cutting fuel. Do you get a CEL when this happens?
To prevent any (or further) damage to your engine take it easy until you know how much boost you are actually running.
Old Sep 11, 2003 | 08:02 AM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
Originally posted by pnytamer
a boost gauge comes with the car and from i understand .05 is 7psi and i turned it up to halfway between .1 bar and .15 bar. is that too much boost on the factory turbo? should i invest in a digital boost gauge? what is a CEL?? any help would be great!!!
Incorrect. it's not in bar, it's MPa. The conversion is different. Your overboosting, turn it down.
.05 = 7.25
.06 = 8.70
.07 = 10.15
.08 = 11.60
.09 = 13.05
.10 = 14.50
.11 = 15.95
.12 = 17.40
Old Sep 11, 2003 | 02:29 PM
Mulder's Avatar
CEL= Check Engine Light
The boost gauge doesn't automatically come with the car, it is an option. Apparently your car had one.
Yes that is way too much boost on the stock turbo and engine management. Keep it under 16 psi, 15 is probably the most you want to go.
unstble
Mar 21, 2008 09:09 AM
resident smurf
May 30, 2005 08:17 PM
Eggman's-STI
Oct 5, 2004 10:43 AM
disque71
Apr 13, 2004 11:27 PM
brucelee
May 28, 2003 09:47 PM
