EMERGENCY:: Something leaking.. I tihnk it's the freon
Old Jun 20, 2003 | 12:34 PM
InfamousDX's Avatar
Car Info: '03 WRX Sedan
Well I'm an idiot.. I was installing a grounding kit and I was supposed to ground it to the long 4" bolt t othe alternator, but instead I unscrewed the lower one and then there was a pressure release POP and gaseous stuff was leaking. i think it's the freon to the a/c compressor or something but I retightened the bolt and it still won't stop leaking... HELP!!
Old Jun 20, 2003 | 12:46 PM
InfamousDX's Avatar
And I think whatever is was that was leaking is done leaking. Is this a huge problem or what?
Old Jun 20, 2003 | 02:58 PM
mysubaruimp's Avatar
Car Info: 2001 sub. imp.
dont get it refilled, since its already discharged, take out the pump. more POWAAA
edit:but really, before you get it refilled, you need to check out that bolt, if it was still leaking after you put it back on, it will leak when you fill it up again, maybe wrap it with teflon tape, or make sure it is in there right
JelloChex
Dec 7, 2009 03:11 PM
1neWRX
Feb 7, 2006 11:19 AM
Project Worx
Mar 1, 2005 09:36 PM
imprezaJDM
Aug 21, 2003 11:21 AM
InfamousDX
Jun 25, 2003 09:15 AM
