Can I version 9 swap with usdm ecu?
From what I gather, everything will hook up, just no AVCS. What I'm wondering is can I just use my 02wrx ecu and get a tune until I can get a v7 or v8 ecu? Then rewire for AVCS?
Most of it will hook up.
You need a V9 ECU, V7 and V8 won't do. And there are a lot of other parts you need too. All in all you're gonna spend about $1,500-2,000 on parts needed for AVCS.
Intake manifold
DBW throttle body
Pedal Assembly
AVCS solenoids and wiring harness
ECU
New engine management (unless your tuner can/does OS tune the new ECU)
Whoever wrote whatever you read is retarded.
idk if you are trying to troll me or what..
edit, ok I think we are misunderstanding each other.. Im talking about a jdm v9 swap. Not usdm v9 swap.
Car Info: 2018 Tacoma TRD PRO
I ran a Jdm ecu with my v7 swap. You can't hook up the AVCS with the usdm 2.0 ecu. And it's a must!! I highly recommend you pick up a v7 or 8 with matching ecu
On a V7 motor yes, not on latter ones.
Fehnix; you didn't sense Brfatal's sarcasm
When he said, "How, pray tell, are you going to plug and play a V8/9 ECU (I stand corrected, I assumed the JDM V9 also had dual AVCS) with a DBC throttle body?"
What he actually means is how are you going to plug and play a v8/9 ecu with your 02 wrx which has drive by cable.
On that note
jdm sti motors v7, v8 , v9 are drive by cable
v9 ecu has immobilizer (many are dual avcs; correct code GD-G)
GDA-F is the term for the GD chassis (were still single avcs)
Factory revisions A and B, amounting from 02/01/2000 to 10/31/2002, are called V7
Factory revisions C and D, amounting from 09/01/'02 to 05/31/'04, are called V8
Factory revisions E, F, G amounting from 03/01/'04 to 04/30/'07, are called V9
GRB bodystyle EJ207 are called V10.
So you will need the v9 ecu (with immobilizer etc if you want to utilize what the pros of having the v9 motor)
So get a v8 sti motor swap =]
wiring should be straight forward, then get the IA performance avcs wires or make your own and add it into the wiring!
Dual AVCS is only worth it if w/e you are getting is coming with it and isn't canbus wiring
On that note
Hmm, I swear the few later EJ207 swaps I've seen had DBW throttle bodies on them.
[edit] Pictures on Google say you're right. My apologies on that count.
