awd power distribution
what is the power distribution between the fromnt and rear awd, like is the front 60% and rear 40% power just for exmaple. thank for your guys input.
brandon |
r:f
mt: 50:50 at: 60:40 both are variable depending on which wheels are slipping... |
It's 50/50 with a viscous coupled diff in the middle on the manual transmission WRX's and on the autos I think it is electronically controlled...
All I know is that if I'm not carefull in the snow the back end can come out from under me.
thanks guys! i really needed this information i just won 15 bucks lol
Re: awd power distribution
[QUOTE][i]Originally posted by nic3krnnamja83 [/i]
[B]what is the power distribution between the fromnt and rear awd, like is the front 60% and rear 40% power just for exmaple. thank for your guys input. brandon [/B][/QUOTE] to be accurate, it varies with the condition of lockup exhibited by the center VC unit in the center differential (in the MT). without that VC you get a 50:50 TORQUE split. power is the product of a force * a distance, so then it becomes more complicated. hth ken |
Re: Re: awd power distribution
[QUOTE][i]Originally posted by ride5000 [/i]
[B]to be accurate, it varies with the condition of lockup exhibited by the center VC unit in the center differential (in the MT). without that VC you get a 50:50 TORQUE split. power is the product of a force * a distance, so then it becomes more complicated. hth ken [/B][/QUOTE] To be REALLY accurate Work = Force * Distance and Power = Work/time :D |
Re: Re: Re: awd power distribution
[QUOTE][i]Originally posted by KmanRuffian [/i]
[B]To be REALLY accurate Work = Force * Distance and Power = Work/time :D [/B][/QUOTE] ahhh... ya got me! ;) ken |
