Need some help with my blow off valve
I have a 2005 WRX. I just got the car and there have been upgrades that I am not 100% on. Does anyone know about Sequential Blow off Valves? I am interested in shutting the thing u without removing it. Any suggestion?
replace it with a stock one?
Plug the EM into the bov or you may get better results if it was posted in the correct section!
[QUOTE=wes0372;2602870]
interested in shutting the thing u without removing it. [/QUOTE] im sorry i dont understand can you clarify ? |
i think what the OP means is... he wants to make the BOV "shut up" without having to remove it?
If this is what you're asking, there is two ways to solve this: 1. Buy a recirculation fitting. This will allow the hose that is currently blocked off to connect to the front of the BOV where it vents the air. I think the fitting is about 20 dollars. 2. Your best option is to just buy a stock BPV and then sell your SSQV. You can probably sell your SSQV for around 150, and get a stock one for around 50. |
ok never mind you got it :lol: |
Stock BPV can be had at a wrecking yard really cheap and yea sell the HKS go buy some different parts with the 150. Sell it on CL though cause they dont move too quickly around here.
