map sensors
I have a supercharged EJ25 out of a (normally aspirated) Forrester using the factory injection components and ECU. I would like to be able to run 5 lbs of boost. The stock map/iat sensor range only goes up to about 2 lbs boost before the voltage is maxed out. Is there a source or does someone know the part number for a map/iat sensor that is 1.5 bar or 2 bar. I can scale the output voltage and fuel pressure to make the ECU happy, but I need to come up with the sensor.
Thanks, Robert |
FTC1 by split second is a 2 bar programmable map sensor with timing retard also.
You can run bigger injectors, ditch the fuel pressure adjustments and be happy. a 2 bar map sensor with 550cc injectors is an awesome combo (I'm using it- and I love it) |
