-   Engine Management (https://www.i-club.com/forums/engine-management-66/)
-   -   GReddy E-Manage Ultimate (https://www.i-club.com/forums/engine-management-66/greddy-e-manage-ultimate-117153/)
Imprezer Nov 6, 2005 08:16 PM
Anyone using it?
I just found out you can get rid of MAF sensor if you use it. That is something I would really much like to do.
Any feedback?
Donkey Nov 8, 2005 03:36 AM
If you can one of these on ebay it be a much easier install and cheaper.Unfortunatly HKS has discontinued them but the still sell all accesories for them. [url]http://www.hksusa.com/categories/?id=1921[/url]
Imprezer Nov 8, 2005 03:38 AM
Greddy my man, greddy. Where did you read me say HKS VPC? ;)
jasonjkl Nov 27, 2005 05:56 AM
I got the ultimate on my car for just 1 day, then had to take it back off. First there was no way to conect the dam thing to control indevidual injectors without a CEL coming on, then connected it the regular emanage way that would control all injectors at the same time and found out the car was bogging. I was told it's a software problem and it's only happening on the wrx/sti.
UK n00b Nov 29, 2005 04:15 PM
Why do you want to get rid of the MAF Alex?
Mike
pj21086 Dec 23, 2005 01:27 AM
Hey Mike, what are u using on ur car? U dont have a MAF either right?
Imprezer Dec 23, 2005 01:30 AM
Mike is running TEC3. I used to run it too and I liked not having a MAF.
pj21086 Dec 23, 2005 07:52 PM
What are the advantages of running without a MAF?
Imprezer Dec 23, 2005 08:09 PM
my turbo's inlet is 3.5". I wanna run 3.5" all the way from the filter to the turbo.
pj21086 Dec 23, 2005 11:05 PM
Couldnt you just build a custom 3.5" MAF housing/intake and then scale/tune for it?
UK n00b Dec 23, 2005 11:50 PM
[QUOTE=pj21086]Couldnt you just build a custom 3.5" MAF housing/intake and then scale/tune for it?[/QUOTE]
Yep, done that and it works, or just move the MAF to the charge pipe that also works.
Mike
Imprezer Dec 24, 2005 03:37 AM
MAF to charge pipe? Nah, thanks. No way it will last in high pressure and oil conditions.
Mike, you can recalibrate the MAF readings if the MAF is in a 3.5" pipe? Will it still "work" right after recalibration?
UK n00b Dec 24, 2005 09:24 AM
[QUOTE=Imprezer]MAF to charge pipe? Nah, thanks. No way it will last in high pressure and oil conditions.
Mike, you can recalibrate the MAF readings if the MAF is in a 3.5" pipe? Will it still "work" right after recalibration?[/QUOTE]
Yes sir we can and have done this, depending on location of your turbo (rotated and such) you may want to distance the MAF from the turbo a little and put it after a bend or two (say CAI and locate MAF in the fender well or so on).
Mike
Imprezer Dec 24, 2005 11:06 AM
So then when people and some tuners say that intakes don't do much and cause trouble it is bs then. My take on this is that of you have a nice intake with high flow filter and sheild (cold air) it will no doubt be better than stock. However, for it to work right, you must recalibrate the MAF. And, since it takes more time, tuners opt to NOT to do it.
Am I correct, Mike?
pj21086 Dec 24, 2005 03:08 PM
^^^ It seems that way :D. But i believe that most intakes are stock maf size. I think its more about the turbulance caused by the cai bends/lengh. I think...
If you put it in the charge pipe would there be any negative effects because of heat? I have the Perrin big MAF and ive heard someone say that the MAF housing will heat soak and cause the ecu to pull timing. Is that true?
