-   Engine Management (https://www.i-club.com/forums/engine-management-66/)
-   -   AP vs OS? (https://www.i-club.com/forums/engine-management-66/ap-vs-os-239529/)
JASC Feb 26, 2012 05:25 PM
AP vs OS?
Hello everybody, im curious if i should go the Cobb AP route or stick with a mild, conservative OS tune?
Reason i ask is i found a guy here in town who is willing to sell an unopened (still in box) cobb ap for 150. Sounds sketch but its legit! I am 100% set on getting a tuner to take a look at my car soon (afr's, boost lag, check up, etc) but im wondering if i should pick up the ap for ****s and gigs or if i should just stick with an OS and save the money?
Im a fairly conservative driver, and im thinking an AP isnt really necessary for what i want or need.
Any input helps guys thanks!!
k-dogg39 Feb 26, 2012 05:43 PM
I would talk to the tuner of your choice to see what they prefer and would recommend. Some tuners don't use OS, some do.
JASC Feb 26, 2012 06:25 PM
my tuner does us OS, im just stuck in the middle and can not decide =0
i like the AP for the features and availability to change maps, but like i said im pretty conservative when it comes to driving. The tickets made an impact on my soul!!!
johndabrit Feb 26, 2012 08:15 PM
I've inquired about open source to cobb transition if i ever bought an ap for switching between E85 and 91 maps. I was told If you are OS tuned your map can be converted to a Cobb map.
DerekB707 Feb 26, 2012 08:21 PM
Advantage of cobb is reading cel's & easy switching between maps. If you don't plan on switching maps, you really don't need it. I've had both types of tunes, I like my AP just for the troubleshooting, but for the normal going price of an AP, you can get an open source protune.
KrAzYkld Feb 26, 2012 08:23 PM
If you can get the AP for that cheap, I say go for it. It is a really good tool to have to check up on boost and AFR (to a certain extent) if you don't have anything to monitor those parameters with. If you decide not to keep it, you can always resell it. Just my .02.
JASC Feb 27, 2012 01:57 AM
I appreciate the input, i might as well buy it just to play around with it for a while. 150 bucks is dirt cheap for an AP. Ive seen used stage 1's run up to 500 on CList. Profit is always a good thing!
Blazingbuda40 Feb 27, 2012 02:12 AM
which version im assuming the v1 because its so cheap
JASC Feb 27, 2012 06:25 AM
yes its a v1, and it has been sitting in his garage for about a year :jawdrop:
EQ Tuning Mar 1, 2012 11:25 AM
don't buy the V1 AP. Its nearly useless at this point.
-- Ed
DerekB707 Mar 1, 2012 12:11 PM
[QUOTE=EQ Tuning;3211964]don't buy the V1 AP. Its nearly useless at this point.
-- Ed[/QUOTE]
Unless you can get it for $50 and use it on the trade in program for a v2. :)
C89ZX7R Mar 29, 2012 07:50 PM
Its probably married to another ecu hence why its hasnt left the shop
