Is your turboback Time Attack proven? The Element Tuning 3-inch Turboback is!
Car Info: Do-Luck Bugeye WRX & 2008 Hydra-powered STI
Not everyone can say their turboback has been used to win races, but now YOU can!
Researched and developed to provide optimal flow and performance, the Element Tuning 3-inch turboback delivers the perfect sound and performance for your 02-07 WRX/STI!
As with all Element Tuning products, the Element Tuning full 3-inch turboback was meticulously designed with performance in mind. Here's Element Tuning's own description of this exhaust package:
Originally Posted by Element Tuning
What separates our downpipe from the rest is that we chose to do something new with the divorced wastegate design. I penned this design almost 5 years ago but finding a manufacturer to produce the system with the quality we wanted proved difficult until now. Since the majority of Element Tuning customers have extensive modifications such as larger bolt-on turbochargers like the GT52 or GT49 we designed this exhaust system to exploit that by running the 3” dowpipe’s centerline on the exhaust wheel and the 2” wastegate dump tube’s centerline with the wastegate flapper valve. To do this is difficult however and required us to intersect the 3” DP with the 2” dump tube. You basically end up with almost the volume of a 5” DP and then the wastegate dump tube follows all the way down to the bottom of the exhaust system where we then angled the dump tube to create a low pressure area, therefore creating a Venturi Effect which further aids in proper wastegate flow.
The other item we altered from the norm was a divider at the turbocharger flange. The reason we did this was that we found in testing that it hurt wastegate performance since the majority of the aftermarket turbochargers swing open in a fashion that dumps wastegate exhaust directly into the divider hurting flow. This is often why “bellmouth” designs have better boost pressure control. Also by forgoing this divider, the system will work with turbochargers that have a divided exhaust housing from the factory.
More information can be found here: Element GT65 OEM Location Turbocharger, 512 WHP Internally Gated, Time Attack Win - NASIOC
Photos:
Downpipe:
Full Turboback:
Video:
In-car footage from the Element Tuning STI itself:
Pricing:
The Element Tuning turboback is available as a complete system, or as either just the divorced wastegate downpipe or catback exhaust. As part of this first sale, we are including FREE SHIPPING TO THE LOWER 48 AND CANADA!
Element Tuning Full 3-inch Turboback: $1099
Element Tuning Divorced Wastegate Downpipe: $449.50
Element Tuning Full 3-inch Catback: $649.50
PACKAGE DEALS AVAILABLE!
Please give us a call at 206.938.7975 to order any of the above and get MORE POWER for your Subaru! Free shipping is only available through forum orders!
WorldONE
Engine and Drivetrain
Apr 14, 2008 12:07 PM
Element Tuning
Nov 17, 2004 06:45 PM
