Tons of JDM Motors, Helix Ti Exhaust *NEW*, Helix Injectors, Gruppe-S Headers, etc.
Hey all,
Just got a bunch of motors in: [b][COLOR=Black]EZ30R H6 Motor - [/COLOR] [COLOR=Red]$1999 + shipping[/COLOR][/b] -3.0 6 cylinder horizontally opposed motor out of the Tribeca -Triport, DBW -The same motor in Perrin's 550WHP 06 STi -Will drop into the GDB chassis [IMG]http://www.gruppe-s.com/Clearance/EZ30.jpg[/IMG] *Picture representative of actual motor. Please PM for picture of actual motor. [b][COLOR=Black]USDM STi Motor - [/COLOR] [COLOR=Red]$3199[/COLOR][/b] -2.5L 4 cylinder horizontally opposed out of USDM STi -465 CHP capable out of the box -AVCS Heads -Will drop into the GDB chassis [IMG]http://www.gruppe-s.com/Clearance/FXT-MOTOR1.jpg[/IMG] *Picture representative of actual motor. Please PM for picture of actual motor. [b][COLOR=Black]USDM LGT Motor - [/COLOR] [COLOR=Red]$2999 + shipping[/COLOR][/b] -2.5L 4 cylinder horizontally opposed out of USDM LGT -465 CHP capable out of the box -Internally the same as the USDM STi motor -WRX or STi intake manifold can be bolted on -AVCS Heads -Will drop into the GDB chassis [IMG]http://www.gruppe-s.com/Clearance/Leg_EJ205.jpg[/IMG] *Picture representative of actual motor. Please PM for picture of actual motor. [b][COLOR=Black]JDM FGT Motor - [/COLOR] [COLOR=Red]$2999 + shipping[/COLOR][/b] -2.5L 4 cylinder horizontally opposed out of USDM LGT -465 CHP capable out of the box -Internally the same as the USDM STi motor -WRX or STi intake manifold can be bolted on -AVCS Heads -Will drop into the GDB chassis [IMG]http://www.gruppe-s.com/Clearance/FXTA.JPG[/IMG] *Picture representative of actual motor. Please PM for picture of actual motor. [b][COLOR=Black]JDM 2.5 SOHC Motor - [/COLOR] [COLOR=Red]$999 + shipping[/COLOR][/b] -2.5L 4 cylinder horizontally opposed out of 2.5i (2.5RS) -Naturally Aspirated -Ideal for sand rails or 2.5RS w/ blown motors [IMG]http://www.gruppe-s.com/Clearance/EJ25-SOHC-DBW.jpg[/IMG] *Picture representative of actual motor. Please PM for picture of actual motor. ----------------------------------------------------------------------- [B][COLOR=Navy][SIZE=4]Built Shortblocks and Motors:[/SIZE][/COLOR][/B] [B][COLOR=Black]Gruppe-S Stage 1 USDM STi Longblock -[/COLOR] [COLOR=Red]$3999 + Shipping (built to order)[/COLOR][/B] We have one blown STi motor that we will be rebuilding into one of our stage 1 longblocks (balanced, forged Wiseco pistons, coated race bearings, etc.). This longblock will be capable of holding 535 crank HP consistantly and will drop into any WRX or STi easily. Build time will be ~3 weeks and a 50% deposit will be required. You will not see this price on a longblock like this again! *Longblock does not include ancillaries located on top of motor or accessories: no water pump, AC condenser, power steering pump, intake manifold, wiring harness, turbo, intercooler, etc. [COLOR=Black]-Gruppe-S / Wiseco Forged Pistons (custom spec) -Gruppe-S Coated High Performance Rod & Crankshaft bearings -Forged STi connecting Rods -Forged STi crank shaft -ARP Headstuds -Cometic Head Gaskets (on long-block option) -Professionally balanced rotating assembly (recommended 7500 RPM redline) -Rehoned cylinder walls -Capable of up to 535HP Operation -~3 week build time, 50% deposit required[/COLOR] [IMG]http://www.gruppe-s.com/Clearance/FXT-MOTOR1.jpg[/IMG] *Picture represents product and is not actual product. Actual product is longblock, not motor. [B][COLOR=Black]Gruppe-S 2.2L Stroker Kit for EJ20T -[/COLOR] [COLOR=Red]$1399 + Shipped[/COLOR][/B] These are all the parts needed to build a 2.0L turbocharged motor (WRX or JDM STi) into a serious power making 2.2L stroker motor. This motor should be capable of holding 550 crank HP while revving to 7500 RPM if properly balanced. It includes the following: [COLOR=Black]-Custom spec Wiseco forged stroker pistons -STi forged connecting rods and bolts -STi forged crank shaft -Gruppe-S coated racing bearings[/COLOR] [B][COLOR=Black]Gruppe-S 2.5L Stage 1 Shortblock -[/COLOR] [COLOR=Red]$2599 + shipping[/COLOR][/B] Our Stage 1 shortblock replaces the components we feel are most likely to fail in the USDM STi shortblock. This is essentially a bulletproof USDM STi shortblock and will compliment a GT30R, SZ55, FP Red , FP Green, or TD06-20G sized turbo nicely on 100 octane. WRX owners can benefit from this shortblock also since their heads will bolt right onto it; however, combining their heads with something like the Helix cams and valvetrain and this shortblock would yield something with peak power output similar to the USDM STi. In comparison to other companies' Stage 1 shortblocks, our adds coated race bearings and balancing to within 1 gram (JDM STi motors are balanced to within 7 grams). [COLOR=Black]Features: -Gruppe-S / Wiseco Forged Pistons -Gruppe-S Coated High Performance Rod & Crankshaft bearings -STi Forged Connecting Rods -STi Forged Crankshaft -ARP Headstuds (on long-block option) -Cometic Head Gaskets (on long-block option) -Professionally balanced rotating assembly (recommended 7500 RPM redline) -Rehoned cylinder walls -Capable of up to 535+ CHP Operation -Final Displacement 2.48L -Compression ~8.5 : 1[/COLOR] *Assembly time is generally 3-4 weeks. For the Long block option, we require a core charge for the heads which will be refunded if you heads are in good working order. [B][COLOR=Black]Gruppe-S Stage 2+ 2.5L Shortblock - [/COLOR] [COLOR=Red]$3999 + shipping[/COLOR] [/B] Our Stage 2+ shortblock is built for big numbers. This block is capable of over 625 CHP and 7800 RPM. It will max out a GT35R .82 and anything smaller than that. In comparison to the Stage 1, it adds a nitrated, lightened, and magnafluxed forged STi crankshaft and forged steel Pauter connecting rods. [COLOR=Black]Features: -Gruppe-S / Wiseco Forged Pistons -Coated High Performance Rod & Crankshaft bearings -Reworked high RPM Forged STi Crankshaft -Forged Pauter Connecting Rods -Gruppe-S Stage Two camshafts (AVCS available) (on long-block option) -Gruppe-S Stage Two Valve Train (on long-block option) -ARP Headstuds (on long-block option) -Cometic Head Gaskets (on long-block option) -Professionally balanced and assembled (recommended 7800 RPM redline) -Rehoned cylinder walls -Capable of up to 625+ CHP Operation -Final Displacement 2.48L -Compression ~8.5 : 1[/COLOR] *Assembly time is generally 3-4 weeks. For the Long block option, we require a core charge for the heads which will be refunded if you heads are in good working order. [img]http://www.gruppe-s.com/Subaru/submotors/EJ257B.jpg[/img] Thanks, Mark Phone: (510) 783-5300 We Accept Paypal! Paypal: [email]sales@gruppe-s.com[/email] When ordering w/ paypal, please include the following: product name: XXXX sales rep: Mark Price including shipping: $XXXX Shipping address. |
[B][SIZE=4][COLOR=Black]Helix Injectors:[/COLOR][/SIZE][/B]
[COLOR=Black][B]Helix Power 660cc Injectors for WRX + Walbro 255L FP and setup kit -[/B][/COLOR] [COLOR=Red][B]$539 Shipped! $459 Shipped for just the Injectors![/B][/COLOR] - Ideal for VF series and PE size turbos on WRXs - 340WHP Capable [COLOR=Magenta]- Will work on the 06 WRX [/COLOR] [COLOR=Black][B]Helix Power 820cc Injectors for WRX + Walbro 255L FP and setup kit -[/B][/COLOR] [COLOR=Red][B]$559 Shipped! $479 Shipped for just the Injectors![/B][/COLOR] - Ideal for large turbos on WRX: Green, 20G, GT30R, etc. - 510 WHP Capable [COLOR=Magenta]- Will work on the 06 WRX [/COLOR] [COLOR=Black][B]Helix Power 860cc Injectors for STi + Walbro 255L FP and setup kit -[/B][/COLOR] [COLOR=Red][B]$579 Shipped! $499 Shipped for just the Injectors![/B][/COLOR] - Ideal for 20G, Green, Red, GT30R, GT35R, etc. - 550WHP Capable [IMG]http://www.gruppe-s.com/Subaru/subeng/injectorpumpcombo.jpg[/IMG] [B][COLOR=Black]Gruppe-S Forged Connecting Rods for EJ20T (WRX or JDM STi)[/COLOR] - [color=red]$349 shipped!!![/color][/B] These are super high quality forged steel connecting rods made by a famous JDM aftermarket manufacturer (please e-mail for this info). They will fit in any 2.0L WRX motor (including JDM STi motors). These would be an excellent rod choice for anyone building a 2.0L motor and should support well over 600 WHP. These rods feature ARP L19 rod bolts which are widely considered to be the best on the market. At this price, there is absolutely NO REASON not to use these rods if you're building a 2.0L motor. [COLOR=Black]-Very high quality forged steel connecting rods -Manufactured by a world renowned JDM company ;) - PM FOR MORE INFO -Use ARP L19 con rod bolts (regarded as the best on the market) -Super cheap blow-out price for super high quality part![/COLOR] [IMG]http://www.gruppe-s.com/geoff/conrods.jpg[/IMG] [B][SIZE=4][COLOR=Black]Turbo Packages:[/COLOR][/SIZE][/B] [COLOR=Black][b]IHI VF34 + STI 565CC Injectors [color=red]OR[/color] Helix Power 660cc Injectors + Walbro Fuel Pump[/b][/COLOR] -375HP Capable on a WRX (with proper tuning) -Includes Genuine IHI VF34 -Genuine STI 565cc Pink Injectors -Walbro 255l/h Fuel Pump [b][color=red]$1249 shipped!!![/b][/color] [img]http://www.gruppe-s.com/Specials/Combo.jpg[/img] [COLOR=Black][b]IHI VF34 + STI 565CC Injectors [color=red]OR[/color] Helix Power 660cc Injectors + Walbro Fuel Pump+Ecutek Reflash[/b][/COLOR] -Send us your ECU and we'll reflash it and we'll overnight it back to you [b][color=red]$1949 shipped!!![/b][/color] [COLOR=Black][b]IHI VF34 + STI 565CC Injectors [color=red]OR[/color] Helix Power 660cc Injectors + Walbro Fuel Pump + Installation + Ecutek Reflash + Custom Dynotune[/b][/COLOR] -Please call to schedule an appointment [b][color=red]$2299 shipped!!![/b][/color] Other items: [b][COLOR=Black]Helix RNA Series Valvetrain and Cams- 2001+ Subaru Impreza EJ20 (non-AVCS) - [/COLOR] [COLOR=Red]$999 shipped[/COLOR][/b] The Helix RNA camshafts and valvetrain are designed specifically for high power Subaru applications without sacrificing drive-ability and streetability. The RNA cams work well on the 2.0L platform, with a minor reduction in low end torque while providing truly impressive mid and top end power gains of over 20+ whp, and truly come alive on larger 2.2 or 2.5 liter applications by providing the extra intake and exhaust that the larger displacing engines need.* *Helix Valvetrain is recommended for Helix Cams. -SPECS: 264 Duration, 9.6mm Lift,Titanium Retainers, Dual valve spring, with spring seats -APPLICATION: EJ205 / EJ207 Non-AVCS only -RECOMMENDED MAXIMUM REDLINE: 8500RPM (w/ Helix valvetrain and supporting bottom end only) [B][COLOR=magenta]-This cam and valve train package in the 2.0L WRX heads w/ a 2.5L SB make peak power numbers that are actually better than many of the 2.5L STi motors that we have tuned with similar supporting mods.[/COLOR][/B] [IMG]http://www.gruppe-s.com/Subaru/subeng/Helix_Valvetrain.jpg[/IMG] [b][COLOR=Black]Helix RNA Series Cams- 2001+ Subaru Impreza EJ20 (non-AVCS)[/COLOR] [COLOR=Red]$519 shipped[/COLOR][/b] While it is highly recommended that these cams be used in conjunction with the Helix Valvetrain, they can also be used with your stock valve train (which allows for 10mm of lift). [B][COLOR=Black]Gruppe-S Oil Cooler Kit[/color] - [color=red]$499 Shipped![/COLOR][/B] This Oil Cooler kit was introduced to the public after testing several iterations on Brian Lock's USTCC race car in the deserts of Arizona. The stock WRX and STi lack an oil cooler and running any turbo charged motor hard puts an extreme load on the motor's cooling systems and fluids. Keeping your oil cool not only prolongs the life of your oil but more importantly, it prolongs the life of your motor. This is one of the most overlooked upgrades on the WRX / STi and we feel that anyone who drives their turbocharged vehicle hard should have one. Perhaps that's why the Spec. C comes with an oil cooler from the factory. This oil cooler is track tested on a race winning vehicle and data logs show that it works. In comparison to competitors' oil coolers, the Gruppe-S Oil Cooler features an extremely high quality European core manufactured by a world famous brand and a thermostat of similar quality. Key Features: [COLOR=Black]*High quality European core (240mm x 120mm x 45mm), not some Taiwanese knock off core. *Thermostat operated Oil Cooler to avoid cooling cold oil upon startup. *Aerospace fittings / stainless steel lines, professionally assembled and tested to 1000psi. *Light weight mounting brackets.[/COLOR] [I]In the words of USTCC race car driver Brian Lock, “this oil cooler rocks. After installing this setup we never had a problem with oil temperature again. Even at PIR where it was 115 and it was so hot inside the car I thought my legs were on fire, it was golden. Brian Lock thinks that this oil cooler is the ****, Brian Lock thinks you should buy it.”[/I] [IMG]http://www.gruppe-s.com/geoff/oilcooler.jpg[/IMG] Thanks, Mark Phone: (510) 783-5300 We Accept Paypal! Paypal: [email]sales@gruppe-s.com[/email] When ordering w/ paypal, please include the following: product name: XXXX sales rep: Mark Price including shipping: $XXXX Shipping address. |
[B][COLOR=Black]Helix Full Ti JDM type Exhaust - [/COLOR] [COLOR=Red]$849 Shipped[/COLOR][/B]
Helix has just released a limited edition full titanium exhaust. However, unlike the JIC and Greddy Exhausts, this exhaust is not made from rolled titanium tube; it's made from true tubular titanium (like the Amuse). Again, this is a true JDM spec exhaust system. It is not Chinese made titanium, or constructed by rolling titanium into a tube and then welding it (basically non-seamless tube), The Helix unit uses full JDM aerospace grade titanium that is one piece extruded titanium pipe. [color=black]- Super lightweight 11.5 LBS - JDM Spec SEAMLESS Mandrel Bent Piping - Robotic TIG Welding - Includes gaskets[/COLOR] [IMG]http://www.gruppe-s.com/stuff/Tismall.jpg[/IMG] [COLOR=Black][B]Gruppe-S V2 4-1 Manifold with Jet Hot 2000 - [/B][/COLOR] [COLOR=Red][B]$575 shipped ![/B] [/COLOR] The Gruppe-S manifold is a 4 to 1 unequal length manifold. It will retain your boxer rumble and features T304 Stainless Steel piping, mandrel bends, and CNC precision cut flanges. The 4-1 collector is cast to ensure the smoothest possible low rates. This header is dyno proven to make power; it will not lose power or torque in 2.5L applications anywhere in the RPM range. 2.0L motors will lose some low-end and mid- range power to gain more high-end power and torque. The more modified your vehicle is, the more pronounced the gains from these headers will be. Includes all necessary gaskets. The Jet Hot 2000 outside coating eliminates heat loss from the exhaust gasses (as compared to stock headers). Because warmer air travels more quickly and expands more quickly, this helps to spool the turbo more quickly. [IMG]http://www.gruppe-s.com/Subaru/subeng/ManifoldJet.jpg[/IMG] [b][color=black]Gruppe-S V2 Manifold (non-coated) - 02+ WRX / 04+ STI - [/b][/color][color=red][b]$399 Shipped! [/b][/color] [B][COLOR=black]Cusco Engine/Tranny Mount Combo - 02+ WRX / 04+ STi - [/COLOR] [COLOR=red]$250 Shipped[/COLOR][/B] These mounts are stiffer than the STi Group N mounts and are designed to reduce excessive flex in the stock mounts. [IMG]http://www.gruppe-s.com/Subaru/subeng/cus_mounts.jpg[/IMG] [B][COLOR=black]STi Group N Tranny Mounts - 02+ WRX / 04+ STi - [/COLOR] [COLOR=red]$69 Shipped[/COLOR][/B] [B][COLOR=black]STi Group N Engine Mounts - 02+ WRX / 04+ STi - [/COLOR] [COLOR=red]$95 Shipped[/COLOR][/B] The STI "Group-N" Engine and Tranny Mounts are designed to reduce excessive motion of your motor and transmission during hard acceleration, deceleration, and cornering. This is done by increasing material stiffness over your stock engine and tranny mounts. By decreasing this type of motion, more energy is focused to the drivetrain rather than shifting the engine and tranny. [COLOR=Magenta]These make an excellent replacement for the liquid filled platic units that are standard issue in the 06 STi.[/COLOR] [IMG]http://www.gruppe-s.com/Subaru/subtrn/sti_tm_l.jpg[/IMG] [IMG]http://www.gruppe-s.com/Subaru/subeng/Enginemounts.jpg[/IMG] [B][COLOR=black]STi Group N Engine/Tranny Mount Combo - 02+ WRX / 04+ STi - [/COLOR] [COLOR=red]$159 Shipped[/COLOR][/B] [COLOR=Black][b]Greddy Front Mount Intercooler - 02-05 WRX / 04 STi - [/b][/COLOR][b][color=red]$849 Shipped!!![/b][/color] Because of it's smaller core size and piping size, this is an excellent FMIC for people who have smaller turbos on their WRXs and STis (VF34, 16G, etc.) [IMG]http://www.gruppe-s.com/Subaru/subeng/grd_ic.jpg[/IMG] [COLOR=black][B]Gruppe-S Intercooler Hose Kit for 02+ WRX [/B][/COLOR] [COLOR=Red][B]$99 shipped ![/B] [/COLOR] The Gruppe-S intercooler hose kit replaces the corrugated rubber stock y-pipe, smoothing flow and increasing the airflow diameter, making for a nice increase in power and better boost response. Includes a cast-aluminum Y-pipe, premium quality 4-ply silicon hoses, clamps. This kit will work for STi TMICs being installed on WRXs. [IMG]http://www.gruppe-s.com/Subaru/subeng/gruppe-s-IC-kit.jpg[/IMG] [b][COLOR=Black]Apex'i Induction Box - 02+ WRX / 04+ STi - JDM Spec[/COLOR][/b] - [b][color=red]$150 Shipped!![/b][/color] By fully enclosing the filter element and directing the intake air away from the heat soaked engine components, the APEXI WRX induction box helps prevent the ingestion of hot, preheated air from within the engine compartment. This reduction of intake air temperature promotes more efficient combustion, which in turn creates better performance and increased reliability. The box does not include a new filter. [img]http://www.gruppe-s.com/Subaru/subeng/apx_inbox.jpg[/img] [b][color=black]Cusco Radiator Shroud - 02+ WRX / 04+ STI - [/b][/color][color=red][b]$99 Shipped! [/b][/color] [IMG]http://gruppe-s.com/Subaru/subeng/cus_shroud.jpg[/IMG] [COLOR=red][B][SIZE=4]WE STILL CARRY PERRIN TOO! ALL ITEMS CAN BE VIEWED HERE:[/SIZE][/B][/COLOR] [url]http://www.gruppe-s.com/subaru.htm[/url] Thanks, Mark Phone: (510) 783-5300 We Accept Paypal! Paypal: [email]sales@gruppe-s.com[/email] When ordering w/ paypal, please include the following: product name: XXXX Price including shipping: $XXXX Shipping address. |
How many miles on the USDM STi motor ?
Austin |
What's the price for the:
Gruppe-S 2.2L Stroker Kit for EJ20T, Helix Power 820cc Injectors for WRX + Walbro 255L FP and setup kit, Helix RNA Series Valvetrain and Cams, Gruppe-S Oil Cooler Kit and a FP Green turbo shipped to 99801? |
[QUOTE=WRX Rush]How many miles on the USDM STi motor ?
Austin[/QUOTE] We actually have several and they're all under 600 miles. They come out of Subaru factory cars and still need to be broken in. [QUOTE=Pnoy_81]What's the price for the: Gruppe-S 2.2L Stroker Kit for EJ20T, Helix Power 820cc Injectors for WRX + Walbro 255L FP and setup kit, Helix RNA Series Valvetrain and Cams, Gruppe-S Oil Cooler Kit and a FP Green turbo shipped to 99801?[/QUOTE] I'll shoot you a PM. Thanks, Geoff |
Long shot, I know, but any chance Helix will be coming out with some AVCS cams?
Most likely not :(.
Dude, that sucks, I paid for my JDM AVCS and I dont wanna lose it...so far Ive only found Kelford and DPR that make aftermarket AVCS cams, are there any others that you might know of who offer them?
Actually, those are the exact two I would suggest to you.
| All times are GMT -7. The time now is 08:37 AM. |
