Performance Upgrade - Turbo, Injectors, Pumps, Exhaust, Intake, Pistons, Hoses, etc.
Old Mar 28, 2006 | 09:56 AM
RavSpec's Avatar
Car Info: 2002 WRX
IHI- VF22 - $799.99 Shipped
Largest IHI VF series bolt on turbo for WRX STI. Full boost around 3300 RPM. Capable of 320 WHP. Capable of running up to 25 PSI @7000 RPM. Using P-20 housing. Comes complete with coolant pipes and turbo oil drain tube.
we will also included the uppipe to turbo and downpipe to turbo gasket .
IHI-VF30 - $799.99 Shipped
This turbo is come off the GD STi RA utilizing the exhaust housing of a VF24 with the compressor housing between a VF23 and a Vf22. This turbo will start to come on boost at 2800 rpm. Capable of 300 WHP with simple bolt on. Comes complete with coolant pipes and turbo oil drain tube.
IHI-VF34 - $899.99 Shipped
Fastest spooling turbo among VF22, VF30. Using a P-18 housing allow this turbo to spool much faster than VF22. Capable of 300 WHP with simple bolt on. This turbo are used in Spec RA in Japan. Comes complete with coolant pipes and turbo oil drain tube.
PE-1820F With Actuator (A/R 20 Housing)- $1599.99 Shipped
Comes with separative actuator. Running A/R 20 housing. Ball bearing turbo. This turbo allow you hit 350 to 360 WHP. Stock bolt on to 02+ WRX/STi. Full boost at 3800 RPM.
TD05H-16G Stock Bolt On Turbo (350 HP)- $799.99 Shipped
The TD05H-16G is a bolt-on upgrade for the WRX/STI utilizing a Mitsubishi TD05 16G compressor wheel in a TD05 compressor housing capable of supporting 350 HP maximum. The turbine section consists of a Mitsubishi TD05H high flow turbine wheel and shaft assembly and a 7cm 2 nozzle area turbine housing with an internal wastegate port and wastegate actuator calibrated at 9 PSIG. The center housing contains a water jacket and comes complete with coolant pipes installed. Optional actuators are available for this turbocharger in pressures ranging from 10 to 19 PSIG
TD05H-EVO III 16G Stock Bolt On Turbo (395 HP)- $999.99 Shipped
The TD05H-EVO III Big 16G is a bolt-on upgrade for the WRX/STI utilizing a Mitsubishi TD05 EVO III Big 16G compressor wheel in a TD05 compressor housing capable of supporting 395 HP maximum. The turbine section consists of a Mitsubishi TD05H high flow turbine wheel and shaft assembly and a 7cm 2 nozzle area turbine housing with an internal wastegate port and wastegate actuator calibrated at 9 PSIG. The center housing contains a water jacket and comes complete with coolant pipes installed. Optional actuators are available for this turbocharger in pressures ranging from 10 to 19 PSIG.
TD05H/TD06 -18G or - 20G Stock Bolt On Turbo (400~440 HP)- $1199.99 Shipped
The TD05H-18G or -20G is a bolt-on upgrade for the WRX/STI utilizing a Mitsubishi TD06 18G compressor wheel in a TD06 compressor housing capable of supporting 400 HP to 450 HP maximum. The turbine section consists of a Mitsubishi TD05H turbine wheel and shaft assembly and a 7cm 2 nozzle area turbine housing with an internal wastegate port and wastegate actuator calibrated at 9 PSIG. The turbine housing is ported and polished in the turbine inlet throat and wastegate port areas to improve exhaust gas flow and boost control via the internal gate. The center housing contains a water jacket and comes complete with coolant pipes installed. Optional actuators are available for this turbocharger in pressures ranging from 10 to 19 PSIG.
TD06H-20G - Bolt On WRX/STi (440 HP)- $1399.99 Shipped
The TD06H-20G is a bolt-on upgrade for the WRX/STI utilizing a Mitsubishi TD06 20G compressor wheel in a TD06 compressor housing capable of supporting 440 HP maximum. The turbine section consists of a Mitsubishi TD06H high flow turbine wheel and shaft assembly for maximum HP potential at high RPM on the 2.5L and a 7cm 2 nozzle area turbine housing with an internal wastegate port and wastegate actuator calibrated at 9 PSIG. The turbine housing is ported and polished in the turbine inlet throat and wastegate port areas to improve exhaust gas flow and boost control via the internal gate. The center housing contains a water jacket and comes complete with coolant pipes installed. Optional actuators are available for this turbocharger in pressures ranging from 10 to 19 PSIG.
BT Dominator I Garret Turbo Charger - Bolt On WRX/STi (480 HP)- $1599.99 Shipped
The Dominator I performance turbocharger is a bolt-on upgrade for the WRX/STI utilizing a proprietary Garrett T04E compressor wheel in a Mitsubishi TD06 compressor housing capable of supporting 480 HP maximum. The turbine section consists of a Mitsubishi TD06H high flow turbine wheel and shaft assembly and a 7cm 2 nozzle area turbine housing with an internal wastegate port and wastegate actuator calibrated at 9 PSIG. The turbine housing is ported and polished in the turbine inlet throat and wastegate port areas to improve exhaust gas flow and boost control via the internal gate. The center housing contains a water jacket and comes complete with coolant pipes installed. Optional actuators are available for this turbocharger in pressures ranging from 10 to 19 PSIG.
Zerosport Twin Spool Turbo (A/R 25) - Similar to PE1825- $1799.99 Shipped
This is the same turbo as the PE1825. As opposed to the single-exhaust entry turbine housing on the previous GDB model, the newer JDM GDB STi has the twin-entry, designed for smoother exhaust gas entry to the turbine housing without having exhaust interference. Torque and response at low to mid range are drastically improved by utilizing the ball bearing and the compressor wheel of big 70pai easily supports monstrous 400+ps of power all the way to the high RPM range.
****** TURBO + Upgrade Components ******
VF-22 or VF-30 Turbo Upgrade Kit For 02~05 WRX Only - - $1199 shipped
- VF-22 Turbo or VF-30 Turbo
- Walbro GSS-342, (255 L/H) Fuel Pump
- STI Pink Injectors (545 cc) or SARD 650 cc Injectors (for 02~05 WRX Only)
VF-22 or VF-30 Turbo Upgrade Kit For 04~06 STI Only - - $1399 shipped
- PE 850 cc Injectors
VF-34 Turbo Upgrade Kit For 02~05 WRX Only - - $1299 shipped
- VF-34 Turbo
VF-34 Turbo Upgrade Kit For 04~06 STI Only - - $1499 shipped
- VF-34 Turbo
Zerosport Twin Spool Turbo Kit For 02+ WRX/STI - $3699 shipped
- Zerosport Twin Spool Turbo
- PE 800 cc Injectors For WRX or PE850 For STI
- Zerosport Twin Spool JDM Downpipe
- GT SPEC Twin Spooo Header
- All Required Gasket
- STI Oil Pan (only WRX are required)
- Walbro Fuel Pump
RavSpec's Avatar
Car Info: 2002 WRX
Some Spec on Fujitsubo System:
Fujitsubo has been the leading exhaust manufacture in Japan. Their system are the most quiet and have a deep tone to it. Their system put out are around 85 to 93 dB at 5000 RPM and around 85 to 89 dB at idle. Fujitsubo also are one of the few company that offer one piece cat back system !!! RM01A is their famous one piece cat back system. Most cat back in the market are two piece. If you need a sound clip, email me !!! sales@ravspeconline.com
Fujitsubo Power Getter Cat Back System For USDM WRX/STI :
- PM For Best Price ! (in stock)
- Weight: 12.9 kg (28 lbs)
- 3.5" piping
- Fit fit any US Spec downpipe !!!
- email me for sound / video clip !!!
- in stock for immediate Delivery !!!
- >> More Info <<
Fujitsubo RM01A One Piece Cat Back System For USDM 02~05 WRX/STI
- Weight: 11.6 kg (26 lbs)
- 3.0" piping
- 87 dB Only !!
- >> More Info <<
Fujitsubo RM01A One Piece Cat Back System Special Edition For USDM 06 WRX/STI
- Special edition to clear 06 STI Rear Diffuser !!!!
- 3.0" piping
- 87 dB Only !!
- >> More Info <<
Fujitsubo Legalis-R Cat Back System For USDM WRX/STI :
- Weight: 14.5 kg (31 lbs)
- 85 dB
- 3.0" piping
- >> More Info <<
Fujitsubo Super EX Header For USDM WRX/STI (header only)
- PM for Price(in stock)
- Weight: 5.4 kg
- Equal Length (w/o Upipe)
- >> More Info <<
WEB: www.ravspeconline.com
Email: sales@ravspeconline.com
TEL : 631-586-3520 / 631-964-0032
Old Mar 28, 2006 | 09:57 AM
RavSpec's Avatar
Car Info: 2002 WRX
Greddy EVO2 Cat Back System (WRX) - $559.00 shipped
Greddy EVO2 Cat Back System (STI) - $559.00 shipped
Greddy Front Mount Intercooler (WRX/STI) - $999 shipped
(non-polish piping with V-Spec Core Size: 23.6" x9.6" x 3.0")
Greddy Front Mount Intercooler (WRX/STI) - $1099 shipped
(Polish Piping Included with R-Spec Core Size: 23.6" x9.6" x 3.0")
Greddy Type RS Blow Off Valve Kit - $239 shipped
(including recirculation kit !! )
Greddy Airinx Intake Kit - $139 shipped
Greddy E-Manage - $299 shipped
Greddy E-Manage Ultimate - $544 shipped
Greddy Profec B Spec II - $329 shipped
(Electronic Boost Controller)
Greddy Profec B Type S - $399 shipped
(manual Boost Controller)
Greddy Oil Catch Can - $79 shipped
Greddy Aluminum Radiator For WRX - $599 shipped
Greddy Aluminum Radiator For STI (manual only) - $599 shipped
Greddy TD06S Turbo Kit - PM For Best Pricing
(including uppipe and Greddy Type R Waste Gate)
Old Mar 28, 2006 | 09:58 AM
RavSpec's Avatar
Car Info: 2002 WRX
Koyo Aluminum Radiator For WRX (02~03)- $399.99 shipped
Koyo Aluminum Radiator For WRX / STI (04~05)- $399.99 shipped
Samco Radiator Hose Kit - $99.99 shipped
(2 piece set / blue,red,black)
Samco Intercooler Hose Kit - $113.00 shipped
(3 piece set / blue,red,black)
Samco Turbo Inlet Hose Kit - $299.00 shipped
Walbro Pump GSS-342 With Installation Kit - $89.99 shipped
Walbro Pump GSS-342 Without Installation Kit - $79.99 shipped
Walbro Pump GSS-342 And STI Pink Injector (550cc) - $475 shipped
Great for 02~05 WRX Upgrade !!
Old Mar 28, 2006 | 10:02 AM
RavSpec's Avatar
Car Info: 2002 WRX
HKS Hi-Power Cat Back System For WRX/STI - $529 shipped
HKS Downpipe For 02+ WRX/STI - $159 shipped
HKS SSQV Blow off Valve- $299 shipped
HKS Mega Flow Air Intake Kit - $119 shipped
A'Pex-i AVC-R Electronic Boost Controller - $499 shipped
A'Pex-i S-AFC Air Fuel Controller - $329 shipped
A'Pex-i Turbo Timer (w/ AF Reading) - $89 shipped
A'Pex-i N1 Cat Back System For WRX/STI - $559 shipped
A'Pex-i GT SPEC Cat Back System For WRX/STI - $639 shipped (3.5" Piping)
A'Pex-i Power Intake System For WRX/STI - $119 shipped
A'Pex-i WRX/STI Induction Box - $189 shipped
RavSpec's Avatar
Car Info: 2002 WRX
SARD is the leading manufacture / R&D for racing applications including fuel pressure regulator, pumps, racing blow off valve, and many other racing specific products !!!
SARD Fuel Pressure Regulator - $109
- Available in blue, red or silver
- Extra sensor attachement hole. (1/8 PT)
- in stock !!!
SARD R2D2 Blow Off Valve For 02~04 WRX / STI - $279
- install underneath intercooler. Discrete location.
- high performance spring valve.
- in stock !!
SARD Racing Blow Off Valve For 02~04 WRX / STI - $318
- in stock !!
SARD Super Ex Intake Kit For 02+ WRX/STI - $195
- in stock !!
SARD Trigger Boost Controller - $419
- provide the most constant boost pressure.
- easy installation.
- in stock
SARD Attack Data Display Meter - $179
- record lapse time
- show RPM
- Speed limiter cut
- record 1/4 mile max speed
- in stock
Old Mar 28, 2006 | 10:03 AM
RavSpec's Avatar
Car Info: 2002 WRX
SARD Intercooler Spray Kit - $218
- including tank, pump, controller, hoses, nozzle.
- easy installation
- auto mode available via SARD spray controller
- in stock !!!
SARD Breather Tank - $179
- help cool off coolant temp.
- polish tank
- come with all hoses required
Old Mar 28, 2006 | 10:07 AM
RavSpec's Avatar
Car Info: 2002 WRX
Wiseco Piston and Ring Set
For over 60 years Wiseco has been manufacturing the finest aftermarket forged pistons & performance parts for the snowmobile, motorcycle, ATV, personal watercraft, outboard marine, karting and automotive markets.
1. Valve Pocket designs that allow maximum flow around valve, also allowing oversized valves and high lift cams to be utilized.
2. 2618 extruded material forged for the maximum strength available.
3. High quality piston rings featuring alloy steel contrusction on top ring, cast iron taper faced 2nd, and 3PC oil assembly utilizing atainless expander and carbon steel rails.
4. Wrist Pins constructed of chrome moly steel material for ultimate in strength.
5. No wait time, most piston are available in stock.
********** AVAILABLE APPLICATION **********
- 92.0 mm Stock Bore For EJ20 Engine - $499.99 shipped
- 92.5 mm (0.5 mm / .020) Over Bore For EJ20 Engine - $499.99 shipped
- 93.0 mm (1.0 mm / .040) Over Bore For EJ20 Engine - $499.99 shipped
- 99.0 mm Stock Bore For EJ257 Engine (STI) - $499.99 shipped
- 100.0 mm (0.5mm / .020) Over Bore For EJ257 Engine (STI) - $499.99 shipped
ARP Head Studs Kit For EJ207/EJ257 Engine - $219.99 shipped
Eagle Forged Rods For EJ20/EJ257 Block- $399.99 shipped
Old Mar 28, 2006 | 03:27 PM
orwrx's Avatar
Car Info: WRC replica
SARD 650 cc Injectors< is that direct drop into 02 WRX just like PE650? If so, how much is the injectors alone?
Old Mar 31, 2006 | 12:27 PM
RavSpec's Avatar
Car Info: 2002 WRX
hi:
yes just like the PE !! It will be $415 shipped !
Mark.
Old Apr 6, 2006 | 11:19 AM
orwrx's Avatar
Originally Posted by RavSpec
hi:
Mark.
Mark, are you pretty sure the SARD 650cc PnP like PE. I know PE plugs to factory plug like Pinks, no harness splice like UR or RC. Can you also find out if these injectors drop directly into USDM WRX fuel rail? Someone told me JDM STI V7 topfeed fuel rail is different from USDM WRX tho. I don't see ppl are using this yet, so I need to make sure IT IS PnP like PE. If so, I'll be getting a set.
Old Apr 6, 2006 | 11:20 AM
orwrx's Avatar
Is anyway you can have PE on the side with Sard to see the different?
Old Apr 6, 2006 | 02:33 PM
RavSpec's Avatar
Car Info: 2002 WRX
orwrx: checking for you on that !!
Old Apr 6, 2006 | 06:00 PM
orwrx's Avatar
Lmk!
Old Apr 15, 2006 | 09:11 AM
RavSpec's Avatar
Car Info: 2002 WRX
weekend bump ...
