-   Engine and Drivetrain (https://www.i-club.com/forums/engine-drivetrain-158/)
-   -   Maintenance Services at EQ Tuning (https://www.i-club.com/forums/engine-drivetrain-158/maintenance-services-eq-tuning-237607/)
EQ Tuning Dec 14, 2011 05:23 PM
[b]Many people don't realize, but here at EQ we're not only about performance. We are always happy to perform all minor and major maintenance services on your Subaru's as well! We use only the best fluids and replacement parts and stand behind all the work we do![/b]
Here are just some of the services we offer:
[b]We now offer complete A/C System Services![/b]
Please call for estimates!
[B]30/60/90k Services (WRX/STI):[/B]
Amsoil Synthetic Engine Oil
WIX Oil Filter
Subaru OEM Fuel Filter (2.0l WRX Only)
Subaru Gold ExtraS Transmission Fluid
Subaru OEM LSD Fluid (STI Only)
Subaru OEM Air Filter Element
Subaru OEM Super Long Life Coolant
ATE Super Blue Brake Fluid
General Inspection of all major systems
Labor
We also offer NGK Spark Plugs for the 60k Service
[b]Starting at $395[/b]
[B]Gates Timing Belt Service (WRX/STI):[/B]
- Gates Timing Belt
- OE NTN Timing Belt Tensioner
- OE NTN Timing Belt Idler Pulleys x4
- Subaru OEM Water Pump
- Subaru OEM Thermostat
- Subaru OEM Long Life Coolant
- General Inspection of all major systems
- Labor
[b]Price: $849 OTD![/b]
[B]105k Service (WRX/STI):[/B]
WIX Oil Filter
Gates Racing Timing Belt
Subaru OEM Timing Belt Tensioner
Subaru OEM Timing Belt Idler Pulleys x4
Replacement Accessory Drive Belts
Labor
[b]$1,125[/b]
[b]Clutch Replacement (Exedy Stage 1)[/b]
Exedy Stage 1 Clutch Kit
Downpipe Gasket
Resurface Flywheel
Labor
General Inspection
[b]$1000 WRX / $1100 STI[/b]
[b]Clutch Replacement (RPS Street Max Clutch)[/b]
RPS Street Max Clutch (The best street/performance clutch by a huge margin!)
Downpipe Gasket
Resurface Flywheel
Labor
General Inspection
[b]$1400 WRX / $1500 STI[/b]
[b]Brake Replacement (Stoptech Rotors and Pads)[/b]
Stoptech Slotted Rotors x4
Stoptech Performance Pads
Labor
[b]$695[/b]
We also offer many other parts, services, and combinations. If you have any questions or special requests, please don't hesitate to contact us and we'll be happy to tailor our services to your exact needs.
-- Ed
EQ Tuning Dec 14, 2011 05:47 PM
Bump
norcalbro Dec 14, 2011 05:51 PM
Not bad. My 30k is coming up soon...
EQ Tuning Dec 15, 2011 11:58 AM
Give us a call for an exact quote.
We also offer lower pricing using lower quality fluids, but most of our customers choose the premium fluids for their cars.
-- Ed
EQ Tuning Dec 15, 2011 03:54 PM
04 STI Scheduled for a 60k Service on Tuesday :)
-- Ed
EnticivEclipse Dec 16, 2011 12:17 AM
pm me a price for 90k all oem replacement parts and exedy stage 1
My car is a DD only street no race so let me know if you recommend me getting oem version?
2004 sti
I need to do this in a couple of weeks since my clutch is now slipping in 6th gear full boost.
EQ Tuning Dec 16, 2011 04:30 PM
Replaced power steering pump and installed air pump delete plates on an 06 WRX. Interesting note.... Customer had a 90k Service done at a dealership and they failed to inspect/replace the accessory drive belts. One of them was about to let go completely and the other one is heavily cracked. Replaced both as they should have been in the first place.
-- Ed
EQ Tuning Dec 16, 2011 04:39 PM
[QUOTE=EnticivEclipse;3179211]pm me a price for 90k all oem replacement parts and exedy stage 1
2004 sti
I need to do this in a couple of weeks since my clutch is now slipping in 6th gear full boost.[/QUOTE]
Quote sent!
-- Ed
EQ Tuning Dec 16, 2011 07:02 PM
Finished up a clutch swap and both rear wheel bearings on a 2000 RS.
-- Ed
norcalbro Dec 17, 2011 08:53 AM
Pm me a quote for 30k service on a 2010 wrx. I'm only at 27k, but sooner is better than later.
EQ Tuning Dec 19, 2011 03:09 PM
[QUOTE=norcalbmxer4u;3179666]Pm me a quote for 30k service on a 2010 wrx. I'm only at 27k, but sooner is better than later.[/QUOTE]
Quote sent!
Thank you!
-- Ed
EQ Tuning Dec 20, 2011 02:38 PM
Currently doing a 60k service and compression/leakdown test on an 04 STI.
-- Ed
EQ Tuning Dec 20, 2011 06:04 PM
bump
EQ Tuning Dec 23, 2011 06:19 PM
bump!
EQ Tuning Dec 23, 2011 07:06 PM
Happy holidays!
