JDM STi Spec C 1 Piece Intake Manifold & JDM 'TGV Delete' Intake Manifold Risers
Car Info: 2006 wrx, sr20DET Datsun 510, 2004 Sti, 2001 GC8
This 1 piece manifold come stock on JDM Spec C STi in Japan. You can eliminate the tumbler manifolds completely by installing this 1 piece manifold. Will increase flow and throttle response. Uses top feed style injectors (found on the USDM WRX). If you have an STi that uses side feed injectors you will need to change your injectors. Comes with manifold, RH fuel rail, LH fuel rail and fuel pressure regulator.
JDM STi Spec C 1 Piece Intake Manifold $699.95.
Genuine JDM intake manifold risers are a perfect fit and delete the 'TGV' flapper valves that can resrict the air flow into your engine. Called 'Tumble Generator Valves' by Subaru, these are common in many vehicles and are used to help emissions by closing off a signifigant portion of your intake to 'tumble' the air at idle and low loads, emissions can be improved. At high loads these valves become restrictions. Works with OE or aftermarket fuel rails and injectors. This part fits USDM 2.5L turbo engines using side feed Injectors. Will work with 2004-UP Impreza STi, 2005-UP Legacy GT and Outback GT, and Forester XT.] Will not work with 2006-UP WRX because it uses top feed style Injectors. Your check engine light will need to be 'flashed' off. Sold as pairs.
JDM 'TGV Delete' Intake Manifold Risers $199.95.
Take care,
The Renick Motorsports Team
www.renickmotorsports.com
888-923-8201
714-871-9300
Take care,
888-923-8201
714-871-9300
East Coast WRX
May 3, 2004 09:09 AM
East Coast WRX
Sep 23, 2003 12:50 AM
