-   Engine and Drivetrain (https://www.i-club.com/forums/engine-drivetrain-158/)
-   -   GrimmSpeed Up-Pipe (coated) ALWAYS in stock! (https://www.i-club.com/forums/engine-drivetrain-158/grimmspeed-up-pipe-coated-always-stock-234667/)
LICmotorsports Sep 6, 2011 05:53 PM
[CENTER][img]http://www.licmotorsports.com/sites/default/files/imagecache/product_full/gs%20003002.jpg[/img][/CENTER]
The entire Up-Pipe is made of 304 SS(flanges, flex, tubing) and has a pipe-wall thickness of 14 Gauge, this is the most "heavy-duty" pipe you will find. Many other pipes use cheap thin steel and are marketed as "super light weight", not us. The inlet size is 1.92" and the pipe tapers down to 1.72” which acts as a funnel as it moves into the turbo allowing for the smoothest transition and best air-flow quality. The one of a kind Triple Layer Flex Joint is not located in the bend, which adds to the life expectancy of the flex section. Our outlet size is a perfect match to the most common stock location turbos allowing for a smooth transition into the turbo.
Fitment:
02+ WRX
04+ STi
04+ FXT
04-06 Baja
05-06 LGT
05-09 OBXT
*These are always in stock at LIC Motorsports: [url=http://www.licmotorsports.com/products/grimmspeed-pipe-coated-02-wrxsti-04-fxt_003002]Grimmspeed Up-Pipe Coated (02+ WRX/STi, 04+ FXT) Subaru 003002 | Buy Online from LIC Motorsports[/url]
-Noah
LICmotorsports Sep 14, 2011 03:19 PM
bump
-Noah
LICmotorsports Aug 7, 2012 04:20 PM
bump
-Noah
OneManArmy Oct 22, 2012 10:46 AM
bump for LIC.
