GrimmSpeed Up-Pipe (coated) ALWAYS in stock!
Former Sponsor
From: 865 A Sweetser Ave.Novato, CA (new shop smell too)
Car Info: MY04 STi some call it a race car
The entire Up-Pipe is made of 304 SS(flanges, flex, tubing) and has a pipe-wall thickness of 14 Gauge, this is the most "heavy-duty" pipe you will find. Many other pipes use cheap thin steel and are marketed as "super light weight", not us. The inlet size is 1.92" and the pipe tapers down to 1.72” which acts as a funnel as it moves into the turbo allowing for the smoothest transition and best air-flow quality. The one of a kind Triple Layer Flex Joint is not located in the bend, which adds to the life expectancy of the flex section. Our outlet size is a perfect match to the most common stock location turbos allowing for a smooth transition into the turbo.
Fitment:
02+ WRX
04+ STi
04+ FXT
04-06 Baja
05-06 LGT
05-09 OBXT
*These are always in stock at LIC Motorsports: Grimmspeed Up-Pipe Coated (02+ WRX/STi, 04+ FXT) Subaru 003002 | Buy Online from LIC Motorsports
-Noah
jung187
Dec 4, 2013 08:30 PM
akdmx
Mar 19, 2010 10:52 PM
nic3krnnamja83
Sep 11, 2004 06:23 PM
