Equilibrium Tuning EJ205 CNC Head Services
Old Jun 24, 2010 | 03:50 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
The Problem:
As most people know, when you run a Subaru 2.5l shortblock with 2.0l heads, the compression ratio is too high to run safely and efficiently especially on pump fuel. The common approach to resolve this issue has been to use a thicker head gasket to try to bring the compression ratio down. While this can bring the overall compression ratio down, it is by no means ideal. The resulting combustion chamber shape remains inefficient since you're leaving the 2.0l chamber in the heads untouched. You are in essence reducing the effectiveness of the quench area and introducing several sharp edges to the combustion chamber that can build up heat and cause knock. This makes the engine less efficient than a full EJ257 with EJ257 heads. While some of these setups can tune ok, they generally experience inconsistencies under sustained full throttle operation. Drivability and fuel economy are also adversely affected. Some have also tried using custom pistons to bring down the compression ratio, but this has a very similar effect to a thicker head gasket.
Our Solution:
Instead of using a thicker head gasket or low compression pistons, we decided to try something a bit different. We worked closely with our machine shop to carefully map out the combustion chamber of the EJ257 STI head and create a CNC program to replicate the exact same chamber every time. Using this program, we then set up the 2.0l head castings in the CNC and machine out an exact copy of the 2.5l combustion chamber into each 2.0l head casting. We are then able to use a quality OEM head gasket and maintain the exact compression ratio and combustion chamber shape of a complete STI engine. This improves the effectiveness of the quench area and the overall efficiency of the engine.
The results with this approach shows big improvements not only in overall power output, but especially in terms of crisp, smooth off-boost drivability and torque. We've also seen a significant increase in fuel economy as compared to a standard hybrid build. From a tuning standpoint, the difference is so significant that we had to spend quite a bit of time building new base maps for these builds. Under low load conditions, these setups can run as much as 15-20 degrees more timing advance than a hybrid build with a thicker head gasket. This was a great thing to see as we end up with a timing curve much more similar to a 2.5l STI rather than a 2.0l WRX.
Here are some pictures of the process:
Price: $450 with bare heads. This service can also be combined with any of our other head services such as a valve job and re-surfacing.
Please download and fill out this order form when placing an order or sending in heads: http://eqtuning.com/forms/EQ-HEAD-FORM.pdf
-- Ed
Old Jun 26, 2010 | 01:07 PM
BayAreaSTi23's Avatar
Car Info: 03 Evo 8
bump!
Old Jun 26, 2010 | 03:48 PM
novacaine454's Avatar
Car Info: 2004 wrx 300AWHP
exactly how many cc's are gained by milling the heads?
Old Jun 26, 2010 | 04:25 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
I have to double check the numbers, but I believe its a 4-5cc difference.
-- Ed
Old Jul 7, 2010 | 03:44 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Here is a comparison between the CNC heads and a thicker head gasket approach on a hybrid setup:
The Blue curve is an 02 WRX with an EQ Stage 1 shortblock, EQ Stage 2 heads (w/o CNC) using a thicker head gasket to bring down the compression ratio. Its running a VF43, STI TMIC, Catless TBE, DW740cc injectors, and MBC.
The Red curve is an 04 WRX with EQ Stage 1 shortblock, EQ Stage 2 heads w/ CNC work using a factory STI head gasket. This car is also running a VF43 with STI TMIC, Catless TBE, 07 STI Injectors, and MBC.
I think this is actually a very fair comparison as the setups are very similar and both have our built engine. This really shows the big mid range gains that these CNC heads provide.
-- Ed
Old Jul 8, 2010 | 12:45 PM
Car Info: 03 Evo 8
bump!
Old Jul 12, 2010 | 10:25 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
bump
Old Jul 17, 2010 | 12:31 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
bump
Old Jul 20, 2010 | 01:13 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
bump
Old Jul 21, 2010 | 09:46 AM
Car Info: 03 Evo 8
bump!
Old Jul 21, 2010 | 10:09 AM
Car Info: 03 Evo 8
Hybrid done the right way!
Old Jul 21, 2010 | 10:15 AM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
How do you blend the 2.5l PCV system into the 2.0l system?
I've struggled with this for some time now.
Old Jul 21, 2010 | 10:31 AM
ipozestu's Avatar
Car Info: Broken Subarus
Haven't most shops gotten away from "hybrid" configurations? Speaking from personal experience and the experience of many others, I'm not sure "hybrid" and "right way" belong in the same sentence. Now "hybrid" and "bargain" or "budget" or "unreliable" I can see that. Why would anyone who is performing a "budget hybrid" build want to spend additional money on machining? Seems that it takes budget and bargain right out. All your left with is unreliable. After you count all your clams for a hybrid build with machined heads your right in the realm of a real "right way" build.
Old Jul 21, 2010 | 11:20 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Actually plenty of shops still do hybrid engine builds and they can be very reliable. All of our hybrid builds have been running around with no issues to date and the ones using these CNC heads run especially well. The extra $400 for the CNC work is still much less than one would pay for a full set of STI heads with all the AVCS hardware, and the cars tune out almost identically. Its a great option for anyone who still has a good usable set of 2.0l heads.
That being said, I've seen plenty of poorly built hybrid setups that never end up running well. There are several approaches to the hybrid setup and some work much better than others. We have found this particular approach to work significantly better than any others to date.
-- Ed
Old Jul 21, 2010 | 11:22 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
A couple options. You can add ports to the valve covers or T in the second breather into the primary valve cover ports. The latter is not as ideal but it can work ok. I'm not a fan, however, of simply capping off the second port on the shortblock.
-- Ed
Top
