Transmission Problem? Pics w/ Description
Old Apr 14, 2007 | 08:59 PM
Keisatsu's Avatar
Car Info: Broken ass stock '02 WRX
Last few days I've been hearing a sound that I think is coming from the tranny
As I come to a stop, I can hear a whirring click click click sound (best way I can describe it, happens whether I'm in gear, in gear with the clutch in, applying brakes or coasting without brakes).
After checking all the fluids (oil, tranny oil, etc.) I crawled under the car to make sure nothing looked wrong. I noticed some grease coming out of the driver side axle/transmission interface.
I also noticed some oil around where the shift linkage enters the tranny case.
Car is '02 WRX Manual
TIA for your help!
Some pics...
Driver Side Axle>
Driver Side Axle>
Passenger Side Axle for comparison>
Shift Linkage>
Old Apr 15, 2007 | 12:11 AM
1sicwrx's Avatar
That is one dirty under carriage!
Old Apr 15, 2007 | 12:35 AM
Keisatsu's Avatar
Car sees a lot of mud...
Old Apr 16, 2007 | 04:39 AM
Keisatsu's Avatar
bizzump! C'mon guys I know SOMEBODY can steer me in the right direction...
Old Apr 22, 2007 | 01:39 PM
Suby1Man03's Avatar
Could be wheel bearings. The grease is for the splines that come out of the front diff. tear down the axles and clean and grease. for the seal around the shifter linkage u would need to drop the tranny i belive. what kinda oil u use?
Old Apr 24, 2007 | 05:44 PM
Keisatsu's Avatar
I don't think it's the wheel bearings, I've had one go bad, and it didn't sound ANYTHING like this...
Motor: Mobil 1 15000 (changed every 3000)
Tranny/Rear diff: Mobil 1 75-90
Old Apr 24, 2007 | 06:05 PM
ipozestu's Avatar
Car Info: Broken Subarus
Why spend the extra money on a long run oil and change it every 3000miles? What does this have to do with your tranny?
Old Apr 24, 2007 | 07:46 PM
Keisatsu's Avatar
'Cause it makes me feel good...
He asked me what oil I was using, did not specify motor or tranny, for all I know this issue might not be related to the tranny at all, I'm just assuming it is...
Old Apr 24, 2007 | 08:28 PM
ipozestu's Avatar
Just curious, not flaming
Old Apr 24, 2007 | 08:35 PM
Keisatsu's Avatar
:banana:
Old Apr 28, 2007 | 12:23 AM
cbf246's Avatar
Car Info: 04 WRX
kinda sounds like your gears are starting to go out. drain a little bit of the fluid and see if there are any metal shaving and if its black.
Old Apr 28, 2007 | 09:22 AM
Keisatsu's Avatar
good idea, i'll check it out today.
Old Apr 29, 2007 | 12:47 PM
cbf246's Avatar
Car Info: 04 WRX
any news?
Old Apr 29, 2007 | 07:03 PM
Keisatsu's Avatar
yup, kinda...
No metal shavings, but some dirty *** tranny oil! It's not even close to needing to change the oil, but looks like I'll have to doit anyway.
Are those "transmission flush" es a good idea, or a waste of money?
Tranny Oil>
(that little rock on my hand is from putting my hand on the ground, not from the transmission)
Old May 27, 2007 | 11:30 AM
Shazam321's Avatar
Its the grease seal for the cv axle. if its clicking and making noise you might need a new cv axle because all the dirt gets past the seal and mauls it up.
