Please help me do the FAQ.
What are the different gear ratios used by model, year and transmission used. I know I've wondered about those when looking for a used LSD before.
Oh and how about that old link we used to have for the online tire size guide. Where you could enter in your old size and the new size you want to run and it would tell you how close it is to stock by percentages.
Clutch/ Flywheel info:
who makes them for our car?
why or why not get a stronger clutch?
why or why not get a lighter flywheel?
Bushings info:
shifter bushings - what they do & reasons to get or not get them
hardened tranny mount - same as above
hardened rear diff mount - same
-scott-
Bushings info:
-scott-
Re: Please help me do the FAQ.
Originally posted by Imprezer
I am working on FAQ section covering the drivetrain FAQ's.
Please post what you think is a FAQ.
ww
"...axles of evil" - George W. Bush
Might also want to post a link to Mike Shields' site, he has a good article on shifting. http://www.spdusa.com/shifting.htm
-s-
-s-
note: Maybe the above isn't very frequently asked, but I wonder how I can make an informed decision on whether or not to spring the bucks for the swap.
ww
"Go wingless, young man." - Horace Greeley
Car Info: 08 FS/07 FXT/93 GC8 blue/black/black
transmission hmm ok
why can't i tow my car?
where is the fuse to put my car in to FWD mode
what's the deal with the wrx's funky rear diff drive ratio 3.51 to 1
what is the differance between a push, pull and cable clutch
how can i change the locking properties of my V-lsd
Car Info: '02 WRX TurboXS Stage 4
Down Shifting.
Is it hard the engine, transmission, clutch, to down shift? (not necessarily when entering a turn but I know people who say they downshift when breaking to slow there cars for the purpose of "saving their pads.)
what is double clutching?
what tranny oil does the WRC car use? (it's Neo Synthetics BTW)
Why is it hard to shift down into first? (syncros worn out, upgrade fluid and learn to double clutch for the track)
How can I fix the power gap between first and 2nd gear? (upgrade to 6speed, or get a new gear set with 2nd shorter, about 2.00-1 and 1st taller about 3.00-1)
Turbo and High performance Mag has a great WRX tranny section this month!
