need help!
Old Nov 5, 2013 | 02:27 PM
crazymathenia38's Avatar
Car Info: 02 subaru wrx
need help!
I have a 02 wrx and I just replaced the clutch with a exedy clutch and I light weight flywheel and I went to start it back up and the shifter has no play. It won't go into any gear nor is it in neatual and when I started it had a load grinding noise coming from the engine. I don't know if it is the tranny or engine. The starter is not grinding on the flywheel I am so lost please help someone
Old Nov 7, 2013 | 10:55 AM
Heedz's Avatar
Nobody likes the tuna here
you sure it's aligned properly?
Old Nov 8, 2013 | 09:52 AM
yes it is
unstble
Mar 21, 2008 09:09 AM
resident smurf
May 30, 2005 08:17 PM
Eggman's-STI
Oct 5, 2004 10:43 AM
disque71
Apr 13, 2004 11:27 PM
brucelee
May 28, 2003 09:47 PM
