Grinding when putting in 1st gear at stop light (when not moving).
Old Mar 28, 2004 | 07:36 PM
go go go's Avatar
Car Info: GF8 ver6
maybe throwout bearing?
Old Mar 28, 2004 | 08:57 PM
VRWRX's Avatar
Car Info: 2005 CGM WRX Wagon
I had this problem, took it back to Subaru, and they said that my first gear was "chipped." The grinding only happened occassionally...
Old Apr 6, 2004 | 12:28 PM
Gleb83's Avatar
Car Info: 2002 Alpine White WRX
Eventhough synthetic is the same in weight that doesn't mean anything. Synthetic's friction properties are different, it's slicker and because of that your synchros may not be working like they should be.
Old Apr 6, 2004 | 01:32 PM
doughboy's Avatar
Car Info: GDA
yup, your synchros are probably the problem. keep doing it and your 1st will be stripped. try holding clutch down for awhile longer before you shift into gear...it'll allow the synchros to do their job.
a new 1st gear as well as synchros might be in your near future. this is PRECISELY the reason why i will never buy a used WRX -- you don't know how the previous owner treated the car or what he did in terms of modding/servicing.
Old Apr 6, 2004 | 04:22 PM
BlingBlingBlue's Avatar
Mine does it too, only when hot. If I go into first slowly or if I put it in first at a slow roll (essentially rev matched at idle) I do not have this problem.
Dealer said they cannot replicate the problem. If it doesn't get fixed I will likely not consider a Subaru again, which is too bad because I really like this car.
Old Apr 14, 2004 | 09:39 AM
Portland Dave's Avatar
I have this same problem also when the tranny is good and warm from driving at highway speeds. My thinking is that it's an issue with the fluid. When it's really warmed up it's at it's higher viscosity rating and essentially too heavy for the first gear syncro. I've got to keep reminding myself not to shift into first too quickly. I'll probably start trying different fluids like many others have done to alleviate the problem.
Old Apr 19, 2004 | 09:05 AM
methodical's Avatar
Car Info: 2002 wrx wagon
what sort of tranny oil would you recommend using then to try to fix the first gear grinding issue?
Old Apr 19, 2004 | 01:24 PM
nic3krnnamja83's Avatar
i say change ut the tranny fluid first and see how it does
Old Apr 21, 2004 | 04:46 PM
pm'd u boosted
