1st gear grind (5MT)
Old Aug 7, 2005 | 01:30 PM
hYpE-R-29's Avatar
1st gear grind!!
Yesterday when I was driving. I was downshifting from 2nd to 1st driving less than 15 mph ..my 1st gear grinded, this happened a couple of times after that. I just had my 30K service done about 2 1/2 weeks ago at MPJ. Was it because I didn't press the clutch all the way?..or is this a normal problem for the WRX??
any ideas?
Thanx in advance
Old Aug 7, 2005 | 01:31 PM
slagehammer's Avatar
Car Info: Twin WRX Turbo VR-4
They are probably your gear synchos. they get worn and cause gridning and will probably need to be replaced soon. They are warrenty-able too.. i think.
Old Aug 7, 2005 | 01:35 PM
hYpE-R-29's Avatar
i have 31K miles and its a 02...i think my warranty is over, unless its a power train thing?????...also could it be the tranny fluid that MPJ changed 2 weeks ago???
Old Aug 7, 2005 | 01:39 PM
Jumpman23's Avatar
Car Info: 2004 PSM WRX
this also coulda happened because you didnt put it all the way into gear . . .
Old Aug 7, 2005 | 01:43 PM
hYpE-R-29's Avatar
it only did it twice, you guys think any damage occured???...i'll drive again today, hopefully it doesn't happen...if not I think Im gonna replace the tranny fluid again???
Old Aug 7, 2005 | 01:50 PM
A 04 GUIZE's Avatar
Car Info: 06 EVO IX 67 COUPE DEVILLE
im telling you right now it is your 1st gear syncho.mine did the same thing.
Old Aug 7, 2005 | 01:51 PM
hYpE-R-29's Avatar
let me guess repairable by dealer?? any with my luck right after my warranty expires, Subaru says my warranty expired after delivery date which was 2 months ago
Old Aug 7, 2005 | 01:55 PM
krzyxrevver12's Avatar
Car Info: looking for a gc
the only time you should be shifting into first is from a stop... if you shift into first often like that, its your synchros.. first gear is only to get the car moving, once its moving, even though it may feel boggy at a low speed like that 2nd, should be able to move the car accordingly
Old Aug 7, 2005 | 02:13 PM
XkrazyAsianX's Avatar
Car Info: SGM 135i
... yea 1st gear should definintely be used from a stop only. Shoot when i get lazy in traffic, i'll start my car in second .. just gotta feather the clutch and gas a lil more.
Old Aug 7, 2005 | 02:54 PM
yungjin's Avatar
Car Info: 03wrx =]
15miles per hour sounds pertty fast, you probably have to almost redline your car to properly revmatch a 2-1 shift going that fast
The only times i stick it into first is at a stop or if im slowly rolling
Old Aug 7, 2005 | 03:01 PM
travgwrx's Avatar
any ideas?
Thanx in advance
welcome to the world of subaru
yes this is a consistant problem... something with the linkage i believe
Old Aug 7, 2005 | 03:06 PM
hYpE-R-29's Avatar
I usually throw the car in neutral at 15mph, let it slow down then I shift in 1st gear, this is what i meant on the post..thanks for everyones help.....
Old Aug 7, 2005 | 03:07 PM
hYpE-R-29's Avatar
any recall?...should subaru cover this?
Old Aug 7, 2005 | 05:19 PM
yungjin's Avatar
Car Info: 03wrx =]
oh.. hmm .. then i think you may of forced it into first... dont wanna do that >_<.
if u wanna do 2-1... you gotta double clutch it and rev it pertty high at around 6k or so. i do it here and there but for me at least it doesnt seem to go in reliably, so i dont mess around with it too much...
what tranny oil do you use.. you should try using penzoil synchromesh that might take away your grind... mine shifts like butter Try calling your local autozone to see if they carry it, you won't be dissaopinted.. works great on wrx's... doesnt work so great on sti's tho
Old Aug 7, 2005 | 05:30 PM
GotBoost?'s Avatar
Car Info: 2003 PSM STi
+1
couldnt have said it better myself.
-Ted
