Need help with cam sensors in STI swap
I swaped a 06 STI into my older LGT, which I use to have an older V7 STI installed in. The problem I am coming up against is that the cam sensors on the new heads have a three wire connection, whereas my harness has plugs for two wire cam sensors. The good news is that I have a Hydra ECU, so I could add new plugs in the harness for the new cam sensors.
Does anyone know if this is possible or how to wire it... Or if I should just get the Cosworth cam sensor brackets, and if so can I use the 06 STI cam gears? I would like to avoid spending $160 for brackets if I can. PS: I already have the AVCS wired up and working just fine. |
Anyone ever had any success running the: [url=http://www.titanmotorsports.com/gt101-single-channel-hall-sensor.html]Honeywell GT101 Single Channel Hall Effect Sensor (Wheel Speed, RPM trigger etc)[/url] (Honeywell GT101)
