EJ20/25(carb'd) into 1989 Legacy DL FWD
Old Jun 7, 2004 | 07:38 PM
Kay95's Avatar
when you say carb'd do you mean that legacy you have is because if it has the 2.2 in it in should be injected and that means you can piece together a turbo kit from factory cars and ebay parts
if you can do the work your self it will not be as expensive as if you have a shop do it because 3k will get you a good system
what is the weight of that legacy?
Old Jun 12, 2004 | 04:31 PM
Kay95's Avatar
look on the block because you might have a ea81 i think thats it but i dont think it is a ej18
what you can do is buy the ea81t and build that up
could you get a pic of the engine bay?
Old Jun 14, 2004 | 01:24 PM
Kay95's Avatar
i would like to see that motor
keep a eye on ebay because some good deals go by
ver3 or ver7 ra or 8 ra motor
Old Jun 23, 2004 | 02:05 AM
go go go's Avatar
Car Info: GF8 ver6
This is confusing
WHat is your car again?
DL or Legacy?
I dont think there was Legacy DL and Legacy was born in 1990 I think
EJ18 never came carbed and it is only on Legacy and Impreza
From what you say, it looks like you have DL with EJ18, which is not supposed to be on your car.
and carb on EJ18, which again not to supposed to be there...
but it's great that its working like that
I think your previous owner had a sick project to swap EJ18 block onto DL.
If so, since EJ18 is already on it, you can swap EJ22, EJ25.
You can even put turbo on any of them if you know how to properly tune the carb.
There are tons of exhaust manifold, turbo, intercoolers that people are taking off from WRX.
Old Jun 23, 2004 | 01:20 PM
Kay95's Avatar
the ea81/82? is the 1.8t from the older subys that has forged pistons and forged con rods and closed deck
i heard of a rx turbo that is making 350hp and it only weights 18 or 19 hundred pounds if i remember
when you say saving for a rs you mean 01 not 91 right?
Old Jul 1, 2004 | 10:50 PM
Kay95's Avatar
well if you get a ej20 you can get it with all the wiring needed to convert to fuel injection and you will need to buy a high flow fuel pump
Old Jul 6, 2004 | 02:16 AM
kidatari's Avatar
Car Info: Rust and Salt
A carb'ed EJ25? I guess you could slap a Weber sideflow carb on there or something, but It'd be interesting to set up.
You could also go with any other modern Subaru motor and run something standalone like a Haltech. I beleive Haltech requires only 11 wires to run a subaru motor.
Old Jul 24, 2004 | 11:59 PM
THAWA's Avatar
Some of the non-us first gen legs were carbed, and did come with smaller engines like the ej18 and such. There was one somewhere from south africa with a carbed ej18. Looked wierd but they do exist. If it was me risky, I'd keep it carbed. That's a rare subaru indeed and to convert it for more power is like bleh . Also as with just about every other subaru release here we were a year behind on the legacy's aswell. They were started with MY89 everyplace but here.
