-   Bay Area (https://www.i-club.com/forums/bay-area-15/)
-   -   Standalone ecu and flex fuel sensor (https://www.i-club.com/forums/bay-area-15/standalone-ecu-flex-fuel-sensor-244296/)
chochocho Aug 28, 2012 10:14 PM
Any e85 tuned guys running a gm flex fuel sensor with a standalone ecu? Worth it?
Thanks in advance
strider327 Aug 28, 2012 10:22 PM
Hmm interesting, would like to know the answer to this as well. Also how reliable would it be?
apetron Aug 29, 2012 12:19 AM
I am not, but I am considering this:
[url=http://www.zeitronix.com/Products/ECA/ECA.shtml]Zeitronix ECA : SEMA Award Winning Ethanol Content Analyzer and Flex Fuel Sensor for E-85 and E-85/gasoline Blends[/url]
[url=http://www.zeitronix.com/order/order.htm#ECA]Zeitronix Order Page : Wideband Engine Datalogging Systems and Accessories[/url]
PROcede Aug 29, 2012 12:23 AM
Do you e85 guys test your e85 at every fill up?
That sensor above is something Im going to invest in when I do the full switch
apetron Aug 29, 2012 12:31 AM
[QUOTE=PROcede;3285374]Do you e85 guys test your e85 at every fill up?
That sensor above is something Im going to invest in when I do the full switch[/QUOTE]
Nope. I've only tested it once or twice in the 2 years I've been using it. Propel is supposedly pretty consistently the same. I've been using the same pump for every fill up and haven't noticed much if any change in performance.
buzzword Aug 29, 2012 09:34 AM
Fine Line did this with a Link plug and play ecu on an 06 WRX - blog post [URL="http://fliblog.wordpress.com/2012/05/07/fli-builds-the-first-true-100-flex-fuel-no-map-switching-subaru-wrx/"]here[/URL].
G_Ride Aug 29, 2012 10:08 AM
[QUOTE=buzzword;3285440]Fine Line did this with a Link plug and play ecu on an 06 WRX - blog post [URL="http://fliblog.wordpress.com/2012/05/07/fli-builds-the-first-true-100-flex-fuel-no-map-switching-subaru-wrx/"]here[/URL].[/QUOTE]
interesting....
chochocho Aug 29, 2012 10:34 AM
my car is getting a tune at FLI and Miles suggested it if i was to go E85. i was curious on the reliability of the sensor and if there are others running it in the bay area.
seems like a good option to have.
Javirex23 Aug 29, 2012 10:54 AM
Wow! So the Link ECU (with help of the sensor)reads the content of ethanol and adjusts the tune accordingly? Does it only work for e85 or can someone fill up with 91 and have the ECU adjust itself to it?
That is impressive either way?
buzzword Aug 29, 2012 12:35 PM
[QUOTE=chochocho;3285511]my car is getting a tune at FLI and Miles suggested it if i was to go E85. i was curious on the reliability of the sensor and if there are others running it in the bay area.
seems like a good option to have.[/QUOTE]
I would imagine that the OEM GM sensor would be very reliable, since it is installed on hundreds of thousands of FlexFuel vehicles all over the world. I'd be willing to bet that it's infinitely more reliable than any number of the aftermarket parts we run on our cars day in and day out.
To answer Javi's question, yes - it will adjust the map on the fly for 91 octane as well. True Flex Fuel functionality.
FL4T Aug 29, 2012 12:44 PM
There is also a company called Pro Efi that does this as well, where it changes your map on the fly as it reads the octane level of the E85. Their closest shop that would be able to do the tuning and install is in LA though. I've emailed them before and they said they would be able to do it on an STi. They have them already on Evos and Supras
apetron Aug 29, 2012 12:58 PM
[QUOTE=FL4T;3285614]There is also a company called Pro Efi that does this as well, where it changes your map on the fly as it reads the octane level of the E85. Their closest shop that would be able to do the tuning and install is in LA though. I've emailed them before and they said they would be able to do it on an STi. They have them already on Evos and Supras[/QUOTE]
Both Ed from EQ and Mike from GST have said they can do this tuning with the Zeitronics kit if I recall correctly. There was another thread that had this exact conversation in it.
strider327 Aug 29, 2012 01:10 PM
[QUOTE=apetron;3285620]Both Ed from EQ and Mike from GST have said they can do this tuning with the Zeitronics kit if I recall correctly. There was another thread that had this exact conversation in it.[/QUOTE]
So Zeitronics kit and a GM sensor equals Fuel Flex and tuning equals fuel flex for our cars?
apetron Aug 29, 2012 02:08 PM
[QUOTE=strider327;3285629]So Zeitronics kit and a GM sensor equals Fuel Flex and tuning equals fuel flex for our cars?[/QUOTE]
Need a few other things in order to run E85. The Zeitronics and the sensor are just extra stuff to run it dynamically from what I know. I am not sure if using the Zeitronics kit and tuning it with it will allow you to switch between 91 and E85 at will.
You need fuel pump and injectors mostly.
There is another thread floating around that has all of the info. Not sure where it is though.
strider327 Aug 29, 2012 02:44 PM
[QUOTE=apetron;3285665]Need a few other things in order to run E85. The Zeitronics and the sensor are just extra stuff to run it dynamically from what I know. I am not sure if using the Zeitronics kit and tuning it with it will allow you to switch between 91 and E85 at will.
There is another thread floating around that has all of the info. Not sure where it is though.[/QUOTE]
Oh I understand that. I'm sure most of us that have turbo upgrades or such have these components already. Besides this Zeitronics kit, the sensor and the actual tuning to make this all work.
