Boost question/problem
Old Jun 6, 2014 | 11:36 AM
Animal408's Avatar
Car Info: 2003 WRX Wagon
ok so i installed a boost gauge using the top vacuum line off the stock BOV. when i boost the needle flutters between the 10 and 15 psi notches. what are the possible causes for this and i apologize if there is already a thread on this
Old Jun 6, 2014 | 12:12 PM
FL4T's Avatar
Car Info: 06 AW STi
1. leak in the connection where you tapped the hose in or at the gauge end.
2. loose wastegate actuator
3. cracked wastegate
do you feel your car jerking around when you boost? 10-15 is a pretty big range
Old Jun 6, 2014 | 02:43 PM
Scoobywax's Avatar
Did you use the supplied restrictor pill in the line between the t and gauge? If u don't use one the needle won't dampen and it will flutter.
Since you said the boost needle flutters and not boost. It's a needle dampening problem not a boost issue as stated above.
Old Jun 6, 2014 | 02:44 PM
Animal408's Avatar
i havent noticed the car jerking. so for the acuator i would need to lengthen or shortened?
Old Jun 6, 2014 | 02:52 PM
Animal408's Avatar
@Scoobywax yeah i used everything that came with the boost gauge. ill check them again when i get home but evrything that came with the kit i used
Old Jun 6, 2014 | 06:02 PM
Scoobywax's Avatar
If it came with a t that has a built in pill you should be good. Some come with an in line pill inside a rod that you enter into the tubing too. Take a pic of your install @ the bpv so I can see it.
Old Jun 6, 2014 | 06:06 PM
Scoobywax's Avatar
Dont touch the actuator right now. You arent surging. Its pretensioned so you dont want to **** it up if you dont need to. Even when i was surging i didnt touch it i just replaced the restrictor pill a little bigger.
Old Jun 6, 2014 | 09:46 PM
Animal408's Avatar
Fixed the problem. The hose was kinked. Thanks scoobywax for the help
2003 WRX Wagon
Old Jun 6, 2014 | 11:07 PM
Scoobywax's Avatar
2003 WRX Wagon
Anytime. Hope i was of help somewhat lol.
Old Jun 7, 2014 | 12:52 PM
Animal408's Avatar
Yeah you were great help thanks man
2003 WRX Wagon
yzercyber
Aug 12, 2005 03:42 PM
STI Blast
Oct 10, 2003 10:22 PM
slvrwrx02
Sep 18, 2003 04:59 PM
WRXXX
Jun 20, 2003 02:15 PM
