Vendor, Tuning, Service, and Parts Review Feel free to discuss vendor experiences but please don't use the forum as your own private soapbox to perpetually bash specific vendors.
GST E85 & 91 Tune
Old 09-08-2013, 09:31 PM
RobbyRing's Avatar
Car Info: 2004 Subaru WRX Java Black Pearl
Originally Posted by Superusdm
Should be a lot of room to grow with those.
What do you mean by grow?
RobbyRing is offline
Old 09-08-2013, 10:15 PM
flat489's Avatar
Car Info: '11 STI
Originally Posted by stylezwest
I'm at 265whp with 286tq with a stock td04 running 14psi on 91 pump
Of course it's a hybrid but the numbers seem off
For e85 and a vf39?
Anyways good go on the e85
what dyno?
flat489 is offline
Old 09-08-2013, 10:37 PM
banned
stylezwest's Avatar
Car Info: hybrid 03 wrx
Originally Posted by flat489
what dyno?
Mustang dyno
stylezwest is offline
Old 09-08-2013, 11:32 PM
RobbyRing's Avatar
Mustang dyno
Wonder what it would be on a diff dyno... Better yet, how about that fictional "to the crank" HP number that dealers put out on their cars. I'd probably be like 350 lol.
Old 09-09-2013, 12:02 AM
de_engineered's Avatar
If you get bigger/higher preforming parts, say you start to feel your current turbo gets to not be enough, or you go FMIC etc., the injectors may prove to be a bottleneck if not sufficiently sized to make the most of those parts.
Heat + O2 + fuel = fire, aka chemical reaction
Which for hydrocarbon fuels means converting the liquid fuel into gas and heat (release of energy from breaking chemical bonds), where the heat causes the gas to expand, pressing the pistons in the cylinder, rotates the crank...
-(Initial) heat is begotten through the spark plugs.
-O2 through higher flowing pipes - in or out, air or exhaust - expunging exhaust opens up room in the cyl to let air in again, and not have any remnant exhaust retard ignition.
-But fuel? That variable can choke tentative higher power.
As said by Superusdm, 1000cc injectors are plenty big, and perhaps can provide more fuel than your current set up can keep up with. Not to say they're flooding the engine, just that with other parts, there is the potential for more power.
HTH
de_engineered is offline
Old 09-09-2013, 12:32 AM
banned
stylezwest's Avatar
Listen to mike @GST You don't want to spin a rod. that's at least 2500 In labor depending who you go to. Not even including the new block you choose..
Old 09-09-2013, 12:36 AM
RobbyRing's Avatar
listen to mike @gst you don't want to spin a rod. That's at least 2500 in labor depending who you go to. Not even including the new block you choose..
Agreed...
Old 09-10-2013, 08:55 AM
General Pimpin'
OneManArmy's Avatar
Seems like he was happy with the service, the tuner, and the results before you guys decided you knew better than one of the best subaru tuners in the world.
Bottom line...
1. Does your car run smooth?
2. Is it reliable?
3. Did you make solid gains?
Then the numbers don't mean anything. Dyno sheets are for guys with small wieners that want to say theirs is bigger than yours. If you car feels right it is right.
Could you have gotten more power... maybe. Safely... maybe not. Every combination and every motor is different. Could you put it on another dyno and get higher numbers and shut most of these guys up... yes. Could you push the car as far as possible to get a better dyno number.... sure. But then in 2 months we'd be reading about how you're blown up and going with another tuner. There are at least 4 cars right now on E85 tunes from another shop that I know of that blew up.
Listen to mike. Bigger is not always better.
You have PLENTY of power for a street car and if you're happy... well... you know what they say about opinions...
OneManArmy is offline
Old 09-10-2013, 11:59 AM
Personally I was curious about who choose the injectors, and more to the point would they be a good size for me. Even the same motor car to car can be apples to oranges depending on history and intended application, but, well, they're still fruit?
Does sound like it's a nice *reliable* tune though - stars that burn twice as bright last half as long.
Old 09-10-2013, 05:44 PM
RobbyRing's Avatar
Good word
I went to GST Motorsports in Hayward. Mike, the owner gave me mod recommendations all along the way. He has a solid track record and I trust his opinion. He will give you the same advice if you call him and tune with him. Great guy!
xhengmanx
02-10-2016 09:46 AM
PikkaGTR
08-08-2010 06:03 PM
downsti
47
01-25-2010 07:10 PM
TunerSTI
09-13-2007 04:12 PM
A170123W
08-24-2007 05:36 PM
Quick Reply: GST E85 & 91 Tune
