For Sale: Bug Eye, Blob Eye, and Hawk Eye parts. Prices reduced!
Car Info: 2004 Subaru Impreza WRX
Hey everyone.
My parts out car has sold and been picked up but I still have a lot of parts left over.
Gotta get this stuff sold so no reasonable offer will be declined.
Some of the parts will only fit on specific year models (Impreza RS, WRX, or STI) while others will fit on any imprezas made between 02-07.
Please see below for details on what I still have.
Entertainment:
Planet Audio 7 display DVD, CD, MP3
MXT Audio Thunder Amp
2 Ample 6 Speakers
Exterior/Body:
2 Tail light Assemblies (Bug Eye only)
Right Fender (Hawk Eye only)
WRX Trunk Wing (02-07 RS, WRX, or STI)
Trunk Deck Lid (02-07 RS, WRX, or STI) Non Wing
Trunk Weather Stripping
Trunk Torsion Springs (Light Duty/ no wing)
Rear Bumper (Bug Eye only)
2 Fog Lights w/ Brackets (Blob Eye only)
Left Rear Door w/ Window & Motor (02-07 RS, WRX, or STI)
Right Front Door w/ Window & Motor (02-07 RS, WRX, or STI)
Left Front Window & Motor (02-07 RS, WRX, or STI)
Right Front Side View Mirror (Blob eye WRX style)
Right Front Fog Light Cover (Blob Eye RS, WRX, or STI)
Fuel Flapper Door (02-07 RS, WRX, or STI)
New Lock Cylinder w/ 2 Keys
Hood Prop Rod
Electrical:
Powertrain Control Module (Naturally aspirated RS computer)
PCM Cover Plate
Main Gauge Cluster (Auto Trans)
Hazard Light Switch
Cruise Control Switch
Head Light/Turn Signal Switch
Washer Switch
Mechanical:
4 Speed Electrical Automatic Transmissions (RS or WRX)
Rear Differential and mounting bracket (RS or WRX)
Engine Bay Area:
Coolant Overflow Reservoir
Washer Reservoir w/ Washer Motor and rubber tube
Interior/Trim:
Rear Bench Seat
Subaru Steering Wheel w/ Airbag
A/C Selector Assembly
Entertainment Console Trim Piece (02-07)
Entire Upper Dash
Under Steering Wheel Dash
Center Dash
Center Console
Front Dash Trim Piece
Gauge Cluster Trim Piece
Steering Colum Lower Trim Piece
Glove Compartment Assembly
Both A Pillar Trim Pieces
Both Upper B Pillar Trim Pieces
Right Lower B Pillar Trim Piece
Both C Pillar Trim Pieces
All Foot Well Trim Pieces
Cigarette Lighter Plug Delete Cover
Main Switch Delete Cover
Aux. Switch Delete Cover
Center Sun Visor
Trunk Release Level (GC?)
Fuel Door Release Lever (02-05 at least)
Exhaust System:
OEM Exhaust Manifold & Cats (non turbo model)
Cat Back Exhaust (3 pipe) w/ 4 Muffler
Suspension:
OEM Front Sway Bar (Bug Eye)
OEM Rear Sway Bar (Bug Eye)
Right Front Lower Control Arm (02-05 RS, WRX, atleast)
Miscellaneous:
Bug Eye 03 Owners Manual
Right Front Seat Belt Assembly
Rear Seat Belt Assemblies
Like I said, no reasonable offer will be declined so gimme a call and we can talk.
808-489-5665
PS: Pictures will follow soon.
Entertainment:
2 Ample 6 Speakers
Exterior/Body:
Hood Prop Rod
Electrical:
PCM Cover Plate
Hazard Light Switch
Washer Switch
Mechanical:
Engine Bay Area:
Interior/Trim:
Rear Bench Seat
Entire Upper Dash
Center Dash
Center Console
Center Sun Visor
Exhaust System:
Suspension:
Miscellaneous:
808-489-5665
Hey everyone,
I sold a few things recently. Below are the things that are still available:
Exterior/Body:
WRX Trunk Wing (’02-’07 RS, WRX, or STI)
2 Fog Lights (GC8 style only)
Left Rear Door w/ Window & Motor (’02-’07 RS, WRX, or STI)
Right Front Door w/ Window & Motor (’02-’07 RS, WRX, or STI)
Left Front Window & Motor (’02-’07 RS, WRX, or STI)
Fuel Flapper Door (‘02-’07 RS, WRX, or STI)
Under engine cover/skid plate (’02-’07 RS, WRX, or STI)
Side skirt rubber molding piece (one side only)
Electrical:
Powertrain Control Module (Naturally aspirated “RS” computer)
PCM Cover Plate
Hazard Light Switch
Washer Switch
Mechanical:
Center drive shaft (trans to rear diff)
WRX OEM intake manifold (EJ205 engine)
Engine Bay Area:
Hood Prop Rod
Power Steering Low Pressure (Return) Hose (Turbo Model)
Interior/Trim:
Center Dash
Center Console
Center Sun Visor
Fuel Door Release Lever (‘02-‘05 at least)
Exhaust System:
Cat Back Exhaust (3” pipe) w/ 4” Muffler (non turbo model)
All OEM heat shields for turbo imprezas (02-05 at least)
Suspension:
Brakes:
2 resurfaced OEM STI front brake rotors (5x100mm bolt pattern)
2 resurfaced OEM STI rear brake rotors (5x100mm bolt pattern)
2 OEM Tokiko front brake calipers w/ mounting brackets (WRX style)
2 OEM Tokiko rear brake calipers w/ mounting brackets (WRX style)
Miscellaneous:
Bug Eye ’03 Owner’s Manual
If you are interested in these pieces, calling is faster than PMing. I only check iclub every now and then.
I'm also interested in trading stuff.
If you have stuff you want to get rid of, I might be interested.
Gimme a call. 808-489-5665
Thanks.
Exterior/Body:
Electrical:
PCM Cover Plate
Hazard Light Switch
Washer Switch
Mechanical:
Engine Bay Area:
Hood Prop Rod
Interior/Trim:
Center Dash
Center Console
Center Sun Visor
Exhaust System:
Suspension:
Brakes:
Miscellaneous:
Thanks.
Pictures can be seen here:
http://s296.photobucket.com/user/Bou...rt%20Out%20Car
Check below for a complete list of available parts.
Prices are clearly listed.
Exterior/Body:
Right Fender (Hawk Eye only) $50
Trunk Torsion Springs (Light Duty/ no wing) $30
Left Rear Door w/ Window & Motor (’02-’07 RS, WRX, or STI) $50 obo
Right Front Door w/ Window & Motor (’02-’07 RS, WRX, or STI) $50 obo
Left Front Window & Motor (’02-’07 RS, WRX, or STI) $20
Right Front Side View Mirror (Blob eye WRX style) $30
Fuel Flapper Door (‘02-’07 RS, WRX, or STI) $10
New Lock Cylinder w/ 2 Keys $10
Under engine cover/skid plate (’02-’07 RS, WRX, or STI) $20
Side skirt rubber molding piece (one side only) $5
WRX turn signal triangle lenses (Blob eye only) $20
Electrical:
Powertrain Control Module (Naturally aspirated “RS” computer) $50 obo
PCM Cover Plate $10
Hazard Light Switch $10
Cruise Control Switch $10
Head Light/Turn Signal Switch $20
Washer Switch $20
Mechanical:
4 Speed Electrical Automatic Transmissions (RS or WRX) $250 obo
Rear Differential and mounting bracket (RS or WRX) $50
WRX OEM intake manifold, partially polished (EJ205 engine) $50 obo
Engine Bay Area:
Coolant Overflow Reservoir $20
Washer Reservoir w/ Washer Motor and rubber tube $20
Hood Prop Rod $10
Power Steering Low Pressure (Return) Hose (Turbo Model) $20
OEM intake ram and silencer $30 for both
Interior/Trim:
A/C Selector Assembly $20
Center Dash
Center Console
Steering Column Lower Trim Piece
Center Sun Visor
Exhaust System:
Apexi N1 muffler (3” inlet, 5” tip) $100
OEM Exhaust Manifold & Cats (non turbo model) $30
All OEM heat shields for turbo imprezas (02-05 at least) $20
Suspension:
OEM Front Sway Bar (Bug Eye) $30
OEM Rear Sway Bar (Bug Eye) $30
Right Front Lower Control Arm (02-05 RS, WRX, atleast) $30
Brakes:
2 resurfaced OEM STI front brake rotors (5x100mm bolt pattern) $50 for set
2 resurfaced OEM STI rear brake rotors (5x100mm bolt pattern) $50 for set
2 OEM Tokiko front brake calipers w/ mounting brackets (WRX style) $50 for set
2 OEM Tokiko rear brake calipers w/ mounting brackets (WRX style) $50 for set
Miscellaneous:
Bug Eye ’03 Owner’s Manual $10
Right Front Seat Belt Assembly $10
Rear Seat Belt Assemblies $40
OEM Impreza jack, jack rod, and tool kit $20
Thanks.
Exterior/Body:
Electrical:
PCM Cover Plate $10
Washer Switch $20
Mechanical:
Engine Bay Area:
Hood Prop Rod $10
Interior/Trim:
Center Dash
Center Console
Center Sun Visor
Exhaust System:
Suspension:
Brakes:
Miscellaneous:
Thanks.
2003 Subaru RS Part Out Car Slideshow by Bourque_photo | Photobucket
Check below for a complete updated list of available parts.
Exterior/Body:
Left Rear Door w/ Window & Motor (02-07 RS, WRX, or STI) $40 obo
Right Front Door w/ Window & Motor (02-07 RS, WRX, or STI) $40 obo
Left Front Window & Motor (02-07 RS, WRX, or STI) $20
Fuel Flapper Door (02-07 RS, WRX, or STI) $10
Under engine cover/skid plate (02-07 RS, WRX, or STI) $20
WRX turn signal triangle lenses $20
Electrical:
Powertrain Control Module (Naturally aspirated RS computer) $40 obo
PCM Cover Plate $5
Washer Switch $20
Mechanical:
Engine Bay Area:
Hood Prop Rod $10
Interior/Trim:
Center Dash
Center Sun Visor
Exhaust System:
Apexi N1 muffler (3 inlet, 5 tip) $100
Suspension:
Brakes:
Miscellaneous:
Bug Eye 03 Owners Manual $10
Thanks.
Exterior/Body:
Electrical:
PCM Cover Plate $5
Washer Switch $20
Mechanical:
Engine Bay Area:
Hood Prop Rod $10
Interior/Trim:
Center Dash
Center Sun Visor
Exhaust System:
Suspension:
Brakes:
Miscellaneous:
Thanks.
New item for sale added.
Exterior/Body:
Electrical:
PCM Cover Plate $5
Washer Switch $20
Mechanical:
Engine Bay Area:
Hood Prop Rod $10
Interior/Trim:
Center Dash
Center Sun Visor
Exhaust System:
OEM WRX axle back exhaust. $100 obo
Suspension:
Brakes:
Miscellaneous:
Thanks.
Exterior/Body:
Electrical:
PCM Cover Plate $5
Washer Switch $20
Mechanical:
Engine Bay Area:
Hood Prop Rod $10
Interior/Trim:
Center Dash
Center Sun Visor
Exhaust System:
Suspension:
Brakes:
Miscellaneous:
Thanks.
Prices reduced. I’m ready to make deals.
Exterior/Body:
Right Fender (Hawk Eye only) $40
Left Rear Door w/ Window & Motor (’02-’07 RS, WRX, or STI) $30 obo
Right Front Door w/ Window & Motor (’02-’07 RS, WRX, or STI) $30 obo
Right Front Side View Mirror (Blob eye WRX style) $20 obo
Electrical:
Powertrain Control Module (Naturally aspirated “RS” computer) $40 obo
PCM Cover Plate $5
Washer Switch $20
Mechanical:
WRX OEM intake manifold, partially polished (EJ205 engine) $40 obo
Engine Bay Area:
Hood Prop Rod $10
OEM intake ram $10
Interior/Trim: Make me an offer!
Center Dash
Center Sun Visor
Exhaust System:
Suspension:
OEM Front Sway Bar (Bug Eye) $20
Miscellaneous:
Thanks.
Exterior/Body:
Electrical:
PCM Cover Plate $5
Washer Switch $20
Mechanical:
Engine Bay Area:
Hood Prop Rod $10
OEM intake ram $10
Center Dash
Center Sun Visor
Exhaust System:
Suspension:
Miscellaneous:
Thanks.
Subi_Bojo
Hawaii Classifieds
17
07-09-2014 05:01 PM
MEDIKATEDWRX
11-28-2012 06:48 PM
