Audio Integrations 05-07 Subaru WRX/STI Sedan 10 Inch Perfect Fit Enclosure
Car Info: 2005 Subaru STi
In good condition. Comes with hardware. Pick up in SF only.
Text me at 4157485523 since Im not on here that much anymore.
$200
Designed to save as much space possible, this Perfect Fit Enclosure™ sits on the driver's side, still allowing access to the spare ( factory trunk liner has to be cut ). Constructed out of hand laid fiberglass and perfectly sealed this enclosure will work well with almost any driver.
Enclosure Specifications:
Internal Airspace: .85 -.90 cubic feet
Mounting Hole Dia: 9.125 inches
Weight: 13 lbs.
Flush Trim Ring inside Dia: 8.875 inches
Examples of a few woofers known to fit: JL Audio W6v2, Alpine Type-r
Each Enclosure comes with: black flush trim ring, high quality terminal cup with the ability to accept up to 8 gauge speaker wire, 3 to 4 feet of 12 gauge speaker wire for inside the enclosure, pre-drilled hole for mounting, mounting hardware with instructions, stuffed with polyfill sound dampening for smoother bass response, and comes with Audio Integrations Full Warranty. (see link below for warranty info)
No Drilling Required!! This Perfect Fit Enclosure™ mounts firmly to your Subaru with only one bolt! Once bolted down with the included hardware, your enclosure won't be going anywhere no matter how crazy you drive! Using a factory hole in your trunk and our pre-drilled hole in the enclosure it makes for an easy and stealthy install. The mounting hole in the enclosure is standard unless otherwise requested. Please contact us before ordering if your needs differ.
Your Enclosure comes standard wrapped in O.E.M. matching carpet and a black vinyl flush trim ring.
$200
Weight: 13 lbs.
ChadG
07-21-2015 07:53 PM
jacobp7201
05-12-2014 11:07 PM
plac
08-12-2008 01:02 PM
Andrew
04-21-2008 03:48 PM
