Subaru Impreza WRX Suspension Adjustable Coilovers kit
Alright here we go. Does anyone know about maXpeedingrods Racing Coilovers? I think they are very good quality and I will recommended for you!
Link:
Features:
* Adjustable ride heightb
* Adjustable pre-lod spring tension
* 24 levels of adjustable damper -- This allows you the ability to perfectly dial in your coilovers system. You can enjoy confortable riding experience in all road conditions.
* Pillow ball top mount -- this design helps combat noise while tuning. It also improves the steering feel and response
* Most components are made from 6063 aluminum with T6 for increased hardness -- the advantages include excellent strength, and aluminum helps keep the weight down.
* Hi Tensile performance spring - Under 600,000 times continuously test, the spring distortion is less than 0.04%. Plus, the special surface treatment is to improve the durability and performance.
* All inserts come with fitted rubber boots to protect the damper and keep clean.
* Improve your handling performance without sacrifice comfortable ride.
* A fast and affordable way to easily upgrade your car's appearance.
* Easy installation with right tools.
* Ideal for any track, drift and fast road and can also be used for daily driving.
Link:
Amazon.com: maXpeedingrods For Subaru Impreza WRX STI GDF Adjustable Coilover Suspension Coilovers kit: Automotive
Features:
why not read the only review left on that link to help you.
as well you have a WRX. the link is for an 05-07 STI the rear struts will not work for your car.
Fit for: Subaru Impreza WRX STI GDF 2005-2007
you get what you pay for.
"Inexpensive made in China knock offs. Will be adequate for street but not up to track environment. Hard to confirm with out bench strut dyno but get the feeling the units have different compression numbers either due to lax factory QC or seals leaking. You get what you pay for holds true here"
xabre1200
10-05-2015 12:02 AM
edzwrx
07-20-2012 11:52 PM
wal.lin
12-04-2005 05:41 PM
subysubaru
03-12-2004 01:19 PM
OakosAutomotive
Vendor Group Buys/Specials
01-09-2003 02:08 PM
