Coilovers adjust help needed
Old 11-28-2016, 10:23 PM
Rudiris's Avatar
Car Info: 2010 sti hatchback
Exclamation Coilovers adjust help needed
So I got some bc coils couple of week ago
For my hatch so I went ahead and install them
THE way they came two week later I cut my fenders
Put my flares and new wheels and I had to adjust
THE ride height but run in to something weird
In the rear my fender gap are even but coils are not even
IS like 3/4 difference one side is showing 2 1/4 and the other
IS 1 1/4 between spring perch and lower collar
Is there something wrong with them
Rudiris is offline
Old 11-29-2016, 06:30 AM
JourdanWithaU's Avatar
2.25 and 1.25 isn't a .75 difference... What are these measurements? Inches? Centimeters? Threads?
Were things even before you cut your fenders?
JourdanWithaU is offline
Old 11-29-2016, 07:49 AM
Rudiris's Avatar
My bad I was a bit tired last night is almost 1 inch difference
In the showing treads of the coils
I don't think they where like this before cuz I mesure them all the same before the install
And didn't do any adjustment at the time I put them on
After the new wheels and the flares that happened
By the way they're bc coils
Rudiris is offline
Old 11-29-2016, 07:54 AM
The flares were cut and mounted evenly?
Old 11-29-2016, 01:23 PM
Rudiris's Avatar
Yeah I check everything line up the same
I was thinking maybe my upper control arm bushing
Are binding causing not to go down all the way
Or there's not enough weight on that side to compress
The spring
Rudiris is offline
Old 11-29-2016, 02:14 PM
Is the subframe flat to the chassis?
You would need a lot of weight to compress one side. You bushings would have to really be binding to make a difference as well.
Have you corner balanced the car?
Old 11-29-2016, 04:32 PM
Rudiris's Avatar
Chassis and subframe are flat
Haven't balance the car yet because tha issue
I'm kinda worrie I'm trying to foxy before I go for alignment
And balance
I check prelude on the preload on the spring they're
Same I don't know what to do now
Rudiris is offline
Old 11-29-2016, 04:34 PM
Rudiris's Avatar
That's why I post here see if someone has had the same problem or it's just me
Rudiris is offline
SuBay
01-08-2015 08:28 PM
lilsubbie04
05-20-2006 10:40 AM
Rat
01-17-2006 10:01 AM
youie
03-19-2003 06:30 AM
Quick Reply: Coilovers adjust help needed
