The "Will this suspension part fit my car?" thread.
Former Sponsor
Car Info: every subaru ever
This is a copy from a thread I did somewhere else but it should be pretty useful here too. I'll continually be adding to it as we learn more about the 08 Imprezas.
This is a work in progress and took me a little while as it is, but I think it's a pretty decent start on finally making an all encompassing "fitment" thread. I tried to make it as easy to go through as possible while still covering everthing. It's still a little confusing. Blame that on Subaru, not me.
PLEASE if you notice I'm missing something, don't flame me.....just let me know! I'll change/add it as soon as I can. And yes, please double check my work.
I may rearrange the organization, but for the time being i'm focusing on content.
Click on your car below: (i'll fix this monday)
1. 1993-2001 Impreza 2.5RS, L, and Outback Sport
2. 2002-2003 Impreza WRX, WRX Wagon, 2.5RS, 2.5 TS Wagon, Outback Sport
3. 2004-2007 Impreza WRX, WRX Wagon, 2.5i, 2.5RS, 2.5 RS Wagon, Outback Sport
4. 2004 Impreza STi
5. 2005-2007 Impreza STi
6. 2008 Impreza 2.5i, WRX, and Outback Sport
Thanks so far to:
UkNuck
TurbojonLS
sixtoo
stoney98
- Andrew
4. 2004 Impreza STi
Thanks so far to:
UkNuck
TurbojonLS
sixtoo
stoney98
- Andrew
Former Sponsor
2002-2003 WRX, WRX Wagon, 2.5RS, 2.5 TS Wagon, Outback Sport
Struts
Springs
Strut tops and Camber Plates
Camber Bolts
Strut Bars
Coilovers
Swaybars and Swaybar mounts/bushings
Endlinks
Other
Wagon Differences
Struts
The following have a specific fitment for 02-03 WRX and RS, and all of the following spring and strut top fitment with these is the same as it is for the stock struts.
1. KYB AGX
2. KYB GR2
3. Koni Inserts (not a complete strut, see here for install http://forums.nasioc.com/forums/show....php?t=1219607)
4. Tokico HP
5. Tokico D-SPEC
6. STi/SPT Version 7
To use OEM or aftermarket struts that have a specific fitment for 04-07 RS, WRX, or 04 STi, you must use 04+ style rear strut tops and 04+ springs.
05+ STi struts will not fit.
Wagons are different, see notes below.
Springs
Springs for 02-03 Impreza RS or WRX will fit.
Springs designed for 04+ Impreza will fit on your 02-03 Impreza struts or 02-03 aftermarket struts, but you must use 04+ rear strut top mounts and the Scooby921 strut spacer. Details on why the spacer is needed available here:
http://forums.nasioc.com/forums/showthread.php?t=563382
Scooby921 Strut Spacer available here:
http://turninconcepts10.chainreactio...5e77d30c577da7
Aftermarket springs designed for Impreza STi will be too stiff for stock struts. OEM STi springs work well though.
You can use 04+ springs with 04-07 RS, WRX and 04 STi struts. You must then use 04+ style rear top mounts.
All 02+ RS, WRX, and STi front strut top mounts and front camber plates will fit the front.
02-03 rear strut tops fit the rear only with 02-03 springs.
04+ style rear strut top mounts require 04+ style springs.
2002-2007 2.5RS, TS, and 2.5i strut tops are softer then both WRX and STi strut tops (which are the same stiffness). confirmed?
WRX and STi strut tops are the same stiffness. STi strut tops are NOT Group N strut top mounts, which are even stiffer.
Camber bolts
All 02-07 Impreza RS, WRX and STi camber bolts are interchangeable and 14mm.
Strut Bars
Front and rear strut bars from any 02-07 RS, WRX, and STi will fit.
Coilovers
Any complete coilover for 02-07 RS, WRX and 04 STi will fit.
05+ STi coilovers will not fit.
All rear swaybars for any 02-07 RS and WRX will fit. STi rear swaybars will mount on the outside of the endlinks and their effectiveness is reduced.
04+ RS, WRX, and STi rear swaybar bushings will not fit 02-03 swaybar mounts.
04+ RS, WRX, and STi rear swaybar mounts will fit and are an upgrade but require 04+ swaybar bushings.
Front swaybars for 02-07 WRX will fit, except on RS models.
02-07 Impreza RS require a specific sway bar to clear the non-turbo headers. WRX and STi front swaybars will not fit an RS.
Endlinks
Wagons require wagon specific front endlinks.
Front endlinks from any sedan 02-07 RS, WRX, or STi will fit the sedan.
Rear endlinks from any 02-07 RS and WRX will fit sedan and wagon. STi rear endlinks will not fit.
Other
All rear lateral links and trailing arms for 02-07 RS and WRX, and 04 STi will fit, except from a wagon. Rear Lateral Links from a STi will require rear STi endlinks and STi rear swaybar. Also see notes on wagon differences.
All front control arms for 02-07 RS, WRX and STi will fit. See notes on wagon differences.
All Anti-lift kits for 02-07 WRX and STi will fit.
Fender Braces do not fit non-turbo models.
WRX Wagon, OBS and 2.5 TS Wagon Differences
Struts
Struts are specific to the Wagon. While sedan OEM and aftermarket struts and coilovers will fit, you will lose negative camber.
This can be corrected with camber bolts and/or camber plates.
The only upgraded struts that retains stock camber numbers are KYB GR2s and Koni inserts in gutted OEM wagon struts.
Springs
Using sedan springs on a wagon often results in a saggy rear end. Prodrive WRX springs are a notable exception. Wagon specific versions are available from a few manufacturers.
Swaybars
Wagon front swaybars are shorter then sedan and require a specific wagon fitment. Sedan bars have been used successfully in certain cases with certain endlinks.
Endlinks
Wagons require wagon specific front endlinks, unless you swap to sedan front control arms.
Other
Front control arms are different. Upgrading to sedan control arms gives you a wider track. It allows you to run sedan front swaybars, of which there are more choices. It also allows you to run sedan struts without losing negative camber, or you can keep your wagon struts and gain negative camber. You will be required to use a sedan front swaybar and sedan front endlinks. It is recommended to use sedan front axles as well, but not required.
Rear lateral links are different. Switching to sedan lateral links requires switching to sedan rear axles.
Struts
Springs
Camber Bolts
Strut Bars
Coilovers
Endlinks
Other
Wagon Differences
Struts
1. KYB AGX
2. KYB GR2
4. Tokico HP
5. Tokico D-SPEC
Springs
Camber bolts
Strut Bars
Coilovers
Endlinks
Other
Struts
Springs
Swaybars
Endlinks
Other
Former Sponsor
2004-2007 Impreza WRX, WRX Wagon, 2.5RS, 2.5 RS Wagon, Outback Sport
Struts
Springs
Camber Bolts
Strut Bars
Coilovers
Endlinks
Other
Wagon Differences
Struts
The following have a specific fitment for 04-07 WRX and RS, and all spring and strut top fitment with these is the same as it is for the stock struts.
1. Koni Inserts (not a complete strut, see here for install http://forums.nasioc.com/forums/show....php?t=1219607)
2. Ohlins Fixed Perch Struts
3. STi Version 8 OEM (2004 USDM STi)
4. STi Version 8 Arai Pink Struts
The following OEM and aftermarket struts for 02-03 Impreza can work in 2 ways.
1. KYB AGX
2. KYB GR2
3. Koni Inserts (there is an 04+ specific version too, so you can just get that)
4. Tokico HP
5. Tokico D-SPEC
Either by using 02-03 springs and 02-03 rear strut top mounts.
OR
By using 04+ style springs, 04+ style rear strut top mounts, and the Scooby921 strut spacer. Details on why the spacer is needed available here:
Springs
Springs for 04-07 RS or WRX will fit.
To use springs designed for 02-03 Impreza, you must use 02-03 Impreza struts and rear strut top mounts.
See strut section above for spring fitment when using 02-03 struts.
Camber bolts
Strut Bars
Front and rear strut bars from any 02-06 RS, WRX, and STi will fit.
Front strut bars for 02-05 Impreza fit the 06-07 WRX but with some difficulty regarding the AC lines. There are a few 06-07 specific front strut bars.
Coilovers
04+ RS, WRX, and STi rear swaybar mounts will fit are an upgrade but require 04+ swaybar bushings.
Front swaybars for 02-07 WRX will fit, except on RS models. Wagons are different, see notes below.
Endlinks
Front endlinks from any sedan 02-07 RS, WRX, or STi will fit the sedan. Wagons are different, see notes below.
Other
All front control arms for 02-07 RS, WRX and STi will fit. Control arms are aluminum for 06 WRX, but fitment remains the same. Wagons are different, see notes below.
2006 Impreza and 2005-2007 Impreza STi use the same steering rack bushings. All other applications will not fit.
WRX Wagon, OBS and 2.5 RS Wagon Differences
Struts
The only upgraded struts that retain stock camber are KYB GR2s and Koni inserts in gutted Wagon Struts.
Springs
Swaybars
Wagon front swaybars are shorter then sedan and require a specific wagon fitment. Sedan front bars have been used successfully in certain cases with certain endlinks.
Endlinks
Other
Front control arms are different. Upgrading to sedan control arms gives you a wider track. It allows you to run sedan a front swaybar, of which there are more choices. It also allows you to run sedan struts without losing negative camber, or you can keep your wagon struts and gain negative camber. You will be required to use sedan front swaybars and sedan front endlinks. It is recommended to use sedan front axles as well, but not required.
Struts
Springs
Camber Bolts
Strut Bars
Coilovers
Endlinks
Other
Wagon Differences
Struts
1. KYB AGX
2. KYB GR2
4. Tokico HP
5. Tokico D-SPEC
OR
Springs
Camber bolts
Strut Bars
Coilovers
Endlinks
Other
Struts
Springs
Swaybars
Endlinks
Other
Former Sponsor
2004 Impreza STi
Struts
Springs
Camber Bolts
Strut Bars
Coilovers
Endlinks
Other
Struts
STi Version 8 OEM or STi Version 8 Arai Pink Struts and Ohlins Fixed Perch Struts are the only direct replacement struts for 2004 STi.
Koni Inserts have a 04 WRX fitment; however they will not fit in 2004 STi strut bodies due to the inverted design of the STi struts. They can be fitted to any 02-07 Impreza WRX or RS strut body. Fitting them to wagon strut bodies will result in extra negative camber. This assembly will fit a 2004 STi without issue. See here for install http://forums.nasioc.com/forums/show....php?t=1219607
1. KYB AGX
2. KYB GR2
3. Tokico HP
4. Tokico D-SPEC
5. STi/SPT Version 7
OR
By using 04+ style springs, 04+ style rear strut top mounts, and the Scooby921 strut spacer, available here:
Springs
Springs designed for 04-07 STi will fit.
Springs for 04-07 RS or WRX will fit, but will be too soft for the stock struts.
Camber bolts
Strut Bars
Coilovers
All rear swaybars from any 04-07 STi will fit. WRX rear sway bars will not fit.
Front swaybars for 02-07 WRX sedan will fit.
Front swaybars for 02-07 Impreza RS will not fit.
Front swaybars for 02-07 Impreza Wagon will not fit.
Endlinks
Front endlinks from any 02-07 wagon will not fit.
Rear endlinks from any 04-07 STi will fit.
Rear endlinks from any 02-07 WRX or RS will not fit.
Other
All rear lateral links and trailing arms for 02-07 RS and WRX, and 04 STi will fit, except from a wagon. Rear Lateral Links from a WRX will require rear WRX endlinks and WRX rear swaybar.
All front control arms for 02-07 RS, WRX and STi will fit, except from a wagon. Control arms are aluminum for STi and have greater caster, except in 07 which have the same amount of caster as the WRX.
Struts
Springs
Camber Bolts
Strut Bars
Coilovers
Endlinks
Other
Struts
1. KYB AGX
2. KYB GR2
3. Tokico HP
4. Tokico D-SPEC
OR
Springs
Camber bolts
Strut Bars
Coilovers
Endlinks
Other
Former Sponsor
Same as 2004 STi, except for:
Struts
The only struts that will fit are Ohlins Fixed Perch Struts and STi Version 9 OEM or STi Version 9 Arai Pink Struts.
Coilovers
Only coilovers specific to 05+ STi will fit.
Strut Bars
Front strut bars for 04-05 STi fit the 06-07 STi but with some difficulty regarding the AC lines. There are a few 06-07 STi specific front strut bars.
All rear strut bars from any 02-07 Impreza fit.
Other
Only Lateral Links specific to 05+ STi will fit.
2005-2007 Impreza STi and 2006 Impreza use the same steering rack bushings, all other applications will not fit.
Struts
Coilovers
Strut Bars
Other
Former Sponsor
Struts
Springs
Camber Bolts
Strut Bars
Coilovers
Endlinks
Other
Struts
93-01 Impreza struts fit all body styles.
The following have a specific fitment for 93-01 Impreza, and all of the following spring and strut top fitment with these is the same as it is for the stock struts.
1. KYB AGX
2. KYB GR2
4. Ohlins Fixed Perch Struts
5. STi Version 1 to 6
6. ???
Using any 02-07 Impreza struts result in certain issues that can technically be corrected.
Springs
Any 93-03 Impreza spring will fit.
It's best to use 93-01 specific springs.
04+ Impreza springs will not fit.
Front camber plates are specific to 93-01 Impreza.
Front camber plates from 02-07 Impreza will fit but need to be rotated to fit, resulting in a different adjustments.
Camber bolts
All 93-07 Impreza RS, WRX and STi camber bolts are interchangeable and 14mm.
Strut Bars
Front and rear Strut bars from any 93-01 Impreza will fit.
Front and rear Strut bars from any 02-07 Impreza will NOT fit. confirmed?
Coilovers
Coilovers for any 93-01 Impreza will fit. Don't bother with anything else.
All rear swaybars for any 93-01 Impreza will fit.
04+ RS, WRX, and STi rear swaybar bushings will not fit 93-01 swaybar mounts.
Endlinks
Rear endlinks from any 93-01 Impreza will fit.
Other
Anti-Lift Kits from any 93-01 Impreza will fit.
Anti-Lift Kits from any 02-07 Impreza will fit, but you do not need the included spacers for the subframe.
Struts
Springs
Camber Bolts
Strut Bars
Coilovers
Endlinks
Other
Struts
1. KYB AGX
2. KYB GR2
6. ???
Springs
Camber bolts
Strut Bars
Coilovers
Endlinks
Other
Former Sponsor
Struts
Springs
Camber Bolts
Strut Bars
Coilovers
Endlinks
Other
Struts + Shocks
Only 2008 Impreza specific struts and shocks will fit.
Springs
Only 2008 Impreza specific springs will fit. (probably)
Not sure yet about fronts.
Rears are probably 2008 Impreza specific.
Camber bolts
Probably 14mm camber bolts up front.
Strut Bars
Not sure on front compatibility, but probably 08 Impreza specific.
Only 2008 Impreza specific rear strut/shock tower bars will fit.
Coilovers
Only 2008 Impreza specific coilovers will fit.
Front swaybar is the same as 05+ Legacy GT.
Not sure on turbo/non-turbo front swaybar compatibility. Probably are not interchangeable though.
Only 2008 Impreza specific rear swaybars will fit.
Endlinks
Not sure on front compatibility.
Only 2008 Impreza specific rear endlinks will fit.
Other
Not sure on sedan and wagon differences yet.
Please help me update this section as info becomes available!
Struts
Springs
Camber Bolts
Strut Bars
Coilovers
Endlinks
Other
Struts + Shocks
Springs
Camber bolts
Strut Bars
Coilovers
Endlinks
Other
WRX lova
07-28-2005 03:12 AM
