You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Hey all. My suspension components are arriving bit by bit this week. (S-Techs showed up this morning, AGXs, Progress RSB and endlinks are not far behind...) I was going through the Tein instructions this morning, and it made mention of the bump stops, and said that it might be necessary to trim them for the install. I checked out the accompanying chart, and for the '02 Sedan, it says:
FRONT:
Cut type = A
inches = 0.6
REAR:
Cut type = A
inches = 1.6
Now, I'm assuming that this means I trim those measurements off the bumpstops. (Please correct me if I'm wrong.) Does any one know what the "cut type" refers to? There's a note on the bottom of the sheet that states, "Refer to the figures shown in the instruction manual for Cut Types." Of course, there's nothing in the manual about it...=)
Strange. You have an '02 as well? I will be installing the AGXs at the same time, so a stiffer shock will help stay clear of the bumpstops anyway, but it's still recommending to trim over an inch and a half from the back. I don't know...
Well, it's not an expensive set of springs, so i'm not out all that much if they don't work for me. I like the drop, so it's a good place to start. Since I won't ever have this car on a track or strip either, I'm not too worried.
Worse comes to worse, I'll swap springs out for a different set.
Of course, I'd rather not cut the bump-stops on this install for that reason...=)
