Go Back   i-Club > GD & GC Series Tech Forums (2007 & Previous Years) > Suspension, Handling, and Brakes
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendors TSB & Recalls
Welcome to i-Club
Reply
LinkBack Thread Tools Search this Thread Display Modes
Old 03-21-2004, 07:43 AM   #1
dubaruwgn97
Personal Sales Rating:
drum to disc conversion
anyone know if the master cylinder and prop valves are the same on my 97 outback sport as a 02 wrx??? Also has anyone swapped their rear drum brakes to discs??? how hard is this to do?? any extra problems i should expect to run into??i know its "not needed" and all but i want everything to look the same under my 17x8's,
Old 03-25-2004, 01:39 AM   #2
Personal Sales Rating: (0)
Drives : POS
I was going to make a similar post as I would like to do an L conversion to a WRX in the near future. All the L's had drums so I need to know what to expect . I will be doing two conversions the first is to tide me over till I can get a 6 M/T and axles, hubs, rear diff., etc.
I was looking at using WRX rotors in the front and possibly WRX, 2000 Legacy, or 90-94 Turbo legacy rotors in the rear. I haven't decided which one for the rear. I would to use the rotors and calipers that would allow me to use the stock master cylinder if at all possible.
Offline
Old 03-28-2004, 10:57 PM   #3
S-Squared
ok, you need the rear hub assembly as a whole ( everything but control arms ) with the brake assy including e-brake cables. It will bolt right up no problem ( I have done a few of these )
NOW
the abs system should work ok, but to verify, make sure your abs ring on the hub has the same number of teeth ( which it should , I check as a precaution ) as the factory one off of your car.
master cyl on a wrx is 1 1/16 the one on yours should be a 15/16 , a bigger cyl should be put in, and you should get a prop valve from the wrx/rs etc ( something w rear disks ) to have the valving right.
The stock master/prop valve will not work quite right if left, and will have adverse effects, I recommend you change them to match the new system.
-Nate
S-squared
Old 03-31-2004, 03:42 AM   #4
Personal Sales Rating: (2)
Drives : GF8 ver6
I did drum to disc conversion (US legacy ones/ endless pads).
First of all, your car needs to be AWD.
My car was FWD and couldn't do disc conversion til I did AWD conversion.
you need brake lines, i didnt realize this til last minuite. haha.
its a good time to invest on stainless steel one. I did.
I'm still using the brake master cylinder that came with the car (94 Impreza L FWD)
I prefer this one because its good ole single stage booster and it works just fine. (my fronts are JDM Legacy B4 RSK brakes with AP pads),
I tried to find propotion valve but my car is nonABS, hard to find.
I dont see any problem using the original one though.
I have 2.5RS proportion valve (ABS) for sale, give me a PM if you are interested.
Offline
I-Club
Subaru WRX
Paid Advertisement
Reply
Tags
brake, conversion, disc, drum, legacy, outback, rear, sport, wrx
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
-= NOT AUTHORIZED OR APPROVED BY OR AFFILIATED WITH SUBARU OF AMERICA OR FUJI HEAVY INDUSTRIES LTD. =-
