Timing belt skipped.
Old 02-18-2015, 01:10 PM
oaklandish_WRX's Avatar
Car Info: 0[[XXXXoXXXX]]0
Originally Posted by Sufabru
I did a compression test as you've stated and what I should've done in the first place. Cylinder 2 the one that's misfiring has zero compression while the rest have 210. I plan on doing a leak test.
Siiigh. I wonder what's wrong and if I can do it my self.
Might re-do the comp test; almost no way you get 210 PSI...brand new (but broken in) is prolly 170-180. It's warmed up when you did this?
+1 on also leak test
oaklandish_WRX is offline
Old 02-24-2015, 09:43 PM
Sufabru's Avatar
Car Info: 1998 Impreza L
Originally Posted by 1JavaBlk_in_Sac
Bent valves?
How difficult is it to replace these?
Sufabru is offline
Old 02-24-2015, 09:45 PM
Sufabru's Avatar
Originally Posted by 02RS25
thats what im thinking. could be unrelated. but after tensioner resused, skipped timing, then zero compression, im leaning towards bent intake
Is it possible for it to be head gasket or wrong timing? Or would the compression be bad in two or more cylinder if that were the case?
Sufabru is offline
Old 02-24-2015, 09:47 PM
Sufabru's Avatar
I don't know how to do a leak test as far as getting each cylinder on top dead center. I've been doing some research on that. \
Is it possible that it's a head gasket or wrong timing that's why the compression's that way?
Sufabru is offline
Old 03-03-2015, 11:16 AM
02RS25's Avatar
headgasket unlikely. youd overheat or see massive amounts of coolant ontop of block if it were leaking from HG. wrong timing, yes could cause misfire. a skipped belt with 2 or more teeth skipped at crank, can and will bend intake valves. replacing valves is a complete overhaul of the engine (minus shortblock) youd have to pull engine and do some head work as well as buy new valves. before that though, you need to determine why it skipped in the first place. do a leakdown test and youll for sure know what is leaking is anything. i have a leakdown tester if you need to borrow one. but youll need an air compressor. PM if needed. GL bud
02RS25 is offline
Old 03-04-2015, 01:50 PM
partywagon42's Avatar
If a valve is bent, you're going to want to do a full cylinder head overhaul. At the very minimum, to function properly, a new valve would need to be lapped and correctly shimmed. I don't know of your mechanical skills and resources (tools/time), but if that is the issue pull the engine, remove the heads. Find a good machine shop in your area and have them service the heads. This will typically involve surfacing and a valve job. They will setup and reshim the valves after machining. Personally, I have never machined a cylinder head for flat 4, being as small as they are I imagine that surfacing MAY not be necessary since warping will have less effect over a shorter distance, but I don't know that for sure.
Any engine guys/machinists chime in. I'm still fairly new to these engines myself.
partywagon42 is offline
Old 03-05-2015, 01:47 PM
H_wells3000's Avatar
Car Info: Too many subarus
No compression = pull motor.
Pull off your heads, plenty of YouTube videos out there, and look at how the valves are sitting. Probably will be able to see the bent valve not seating right.
Take the heads to the machinist, have him replace the bad valve (s), if everything is seating right and gets the ok from him slap it back together with new head gaskets and done.
Have fun
I actually just went through this.
H_wells3000 is offline
Old 03-11-2015, 12:54 AM
Sufabru's Avatar
Thank you. It does seems like I've bent a valve due to a bad timing belt tensioner. I'm at the process of doing a leak down test. Still confuse on how to check for leak in terms of getting cylinders on top dead center.
Sufabru is offline
Old 03-11-2015, 12:56 AM
Sufabru's Avatar
I'm at the process of taking the whole engine out. My first time so I've been doing my study here and there. Thank you for the advice.
Sufabru is offline
Old 03-11-2015, 12:57 AM
Sufabru's Avatar
Have fun
Should I do both sides and do I buy the parts, valves etc? Or the machine shop will do all that? Which machine shop did you go to?
Sufabru is offline
Old 03-18-2015, 09:54 AM
02RS25's Avatar
before tearing down the motor, you can do a leakdown test (wont be as accurate as when engine is warm) or you can pull off heads and either run water in the ports and check for leaks or run air through the ports as well. this will tell you of any valves not seating properly. then you can take the heads to a machine shop to have them replace the bad valves and deck the heads. they supply generic replacement parts, or you can order from subarugenuineparts.com and take parts in to them to have them install. Do both, an overhaul like this should only be done once every 120-150k if and when head gaskets start to wear. Do it right and do it once.
Parts youll need:
gasket set
timing belt (if near or over 100k. also bad tensioner)
valves
fluids and filter
misc hoses if brittle (air/oil) or bulging (coolant)
spark plugs
machining would probably be around 300 for decking and install of valves for both heads
youl need a SOHC cam gear holder. depending where in CA you are, you can borrow mine.
be sure to follow the factory service manual to the letter. study it well before touching bolts
Goodluck bud!
02RS25 is offline
Old 03-25-2015, 02:21 PM
I don't know if they're all like this, but the cams in my ej205 actually have a hex so you can hold them with a wrench to get the bolt out of the gear. Just be very careful not to round out the bolt with an Allen wrench!
Old 03-25-2015, 02:24 PM
02RS25's Avatar
the hex on cam gears for wrx is the same pattern as the "flower" type. different look and not as many edges/points, but they are infact same pattern as others. at least my cam gear holder fits all wrx with flower or hex
02RS25 is offline
Old 04-13-2015, 01:33 PM
Sufabru's Avatar
Parts youll need:
gasket set
valves
fluids and filter
spark plugs
Goodluck bud!
You've offered to help quite a lot and I appreciate that. We need more people like you. I live up North though. Right around San Francisco but thank you so much for offering to help.
I took the heads off while the engine is still in the car. I'm at the process of looking for a machine shop right now. It's my first time dealing with this head gasket replacement, bent valve stuff so hopefully all goes well.
Just a question. I bought a new timing belt and a new timing belt tensioner when I tried figuring out why my car was misfiring hoping that were going to fixing it.
Now I know it's a bent valve for sure but I'm afraid to use the timing belt and the timing belt tensioner that I recently bought because it kept skipping and skipping when I was trying to fix the misfire.
Is it possible that the belt was skipping all the time because the exhaust valve was bent? Once I fix the exhaust valve do you think if I use the same timing belt and tensioner that it would no longer skip?
I feel like just buying a new timing belt and a tensioner to be sure. Will that be a waste of money?
Sufabru is offline
Old 04-13-2015, 01:36 PM
Sufabru's Avatar
There's a great product by Company 23 or something like that. They sell tools to remove the pulley, camshaft and things like that. I would never do another timing belt job without those tools. Got them at rallysportdirect. I'm sure they can be bought somewhere else though.
Sufabru is offline
Quick Reply: Timing belt skipped.
