Summer clean out!! Yes another parts thread.
Hey guys, So parts are piling up in my garage from my recent motor swap, transmission swap and all of the above and its time to clear it out. I will make a list and post pictures up later on.
0. JDM Sti Optional Recaro seats
- Really Clean Almost no wear on the seats
Asking 2300 obo
1. 5x100 Brembo front brakes from a v7 sti.
- Unknown rotors in great condition (came with the rotors from japan)
- Endless brake pads with 7mm of life left
Asking - SSOLD!
2. 5x100 Prodrive/Alcon BBK
- Godspeed rotors from the UK, Has worn rotor rings
- Carbotech Bobcat brake pads 6mm pad life
Asking 700 obo
3. Perrin Catless downpipe Divorced 2002-2007 wrx/sti
- Previous owner painted it flatblack not sure if heat coating or not
Asking 200
4. Perrin Rear sway bar w/ Perrin sway bar mounting bracket, and Rear endlink for 2004 WRX Sedan
- I believe this was when Perrin first produced sway bars as I cant find their marking on it anymore.
- Perrin Sway bar bracket is in Great condition along with Bushings.
Asking 300
5. Borla hush Catback for 2002-2007 wrx/sti
- Great Shape, could use a clean up/wash
SOLD!!
6. 2004 Wrx drivetrain swap
- Includes
-Transmission
-Drive shaft
-Rear differential
-Front and rear axles
-Front and Rear hubs
-Rear hubs have ARP extended Studs installed
-Transmission itself should probably be opened up and rebuilt
Asking 700 for entire setup
7. 2006 Legacy Gt Transmission 5B-TY757VBAAB
- We all know that the legacys had better transmission the wrx
-Includes
-Transmission
-Driveshaft
-Rear diff
-Front and Rear axles
-Front hubs
Asking 1200
8. Whiteline Front strut bar for 2002-2007
- Has slight wear on paint from being so old
Asking 100
9. Kartboy rear endlinks for wrx
Asking 75
10. Forced Performance fp18g TD05 turbo
- Ran for about 5-8k miles
- pushed to about 24psi
- Shoud probably have the Seals replaced as I had issues with my car smoking from oil.
Asking 500 obo
11. Perrin Fuel Rail v1
- missing miscellaneous fuel lines to connect to the fuel line but majority of it is there
Asking 200
12. Perrin Fuel rail v2
- this will only come with just the fuel rail, No lines or fpr adapter
Asking 120
13. Defi Red racer Boost gauge 30psi BNIB
- 52mm
Asking 200
14. Autometer cluster Bezel
Defi Red racer Oil pressure gauge 52mm - missing a black trim ring that is removable to make it look like a defi BF series gauge.
STRI Red boost gauge 30psi 52mm
Asking 350 as the setup I had use or switch out Stri boost gauge and get the Defi boost gauge for 450
15. External Wastegate Setup
-Grimmspeed catless 44mm up-pipe and dump tube
-Tial 44mm Black wastegate (no extra springs)
Setup only has about 3-4k miles on it
Asking 475
. more to add for future reference. Pictures to come at a later time as well when I get a chance to update.
Asking 2300 obo
Asking - SSOLD!
Asking 700 obo
Asking 200
Asking 300
SOLD!!
- Includes
-Transmission
-Drive shaft
-Rear differential
-Includes
-Transmission
-Driveshaft
-Rear diff
-Front hubs
Asking 1200
Asking 100
Asking 75
Asking 500 obo
Asking 200
Asking 120
- 52mm
Asking 200
Asking 475
